First post, by jynx
Yes, I already know the workaround - use the maximum install.
Nevertheless - FLC movie playback is busted if you use the minimum install.
I'm running off a copy of the CD and the unit movies / floating brain in the save/load menu aren't working; they're stuck at the initial frame. The movie starts to play when I first access the save/load menu, but after what looks like 1 frame, it stops and never starts again.
I can't tell if this is a problem with the game itself, or the game running under DOSBox, as windows crashes (video init error) if I try to run the executable at the command prompt.
Any enlightenment would be appreciated.
