Redguard
First post, by JKing
The game database suggests that Redguard should work in DOSBox, but I haven't been able to get past the loading screen; DOSBox hangs after "Initializing combat...". The console shows a bunch of illegal reads and writes, but that doesn't tell me much. Could anyone who's actually got it running post their confguration?
For clarity, I'm trying the software-rendered version in stock DOSBox 0.73 with memory set to 32 megabytes; everything else is at default settings.
Reply 3 of 12, by MiniMax
Rank Moderator
Moderator
64 = bad.
63 = good.
_________________
Reply 5 of 12, by DosFreak
64 is the same as 63 in DOSBox. 😀
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 7 of 12, by austin2359
Also, what is the ideal frequency for redguard. 15,000 seems to start it, but once it starts, it has to be somewhere between 30,000 and 60,000 to run smoothly.
Has anyone played with this enough to arrive at the best configuration.
Reply 10 of 12, by DosFreak
RedGuard is a DOS game that uses a crappy Windows installer.
Reply 11 of 12, by frobme
It was a hilarious awful idea at the time; it was a DOS game that required Windows (for the installer and a memory manager) but was also 3D. Soooo many people couldn't run it, due to various system deficiencies or the usual giant pile of bugs that came with a Bethesda game.
Groundbreaking in its own way, but they must have been on serious drugs figuring on a DOS game that required Windows.
