First post, by Drexciyan_Wavejumper
I'm new here, so "Hi" to all, at first! 😎
My system:
Intel Quad Core Q6600 @2,4 GHz (I guess it's 2,4 x 4 = 9,6 GHz)
4GB RAM
Geforce 8800 GT
Soundblaster X-Fi Xtreme Audio
Windows Vista 64Bit (regrettably)
Dosbox 0.73
Well, I have experienced some troubles running WC4 via dosbox.
At least, I achived to avoid that stuttering audio problem within the videos after some trial & error. (I use fixed cycles @50000 now)
But unfortunately I have two big problems within the flying part of the game.
1) The game is stuttering (right word?). When I only fly alone with a wingman the game seems to be smooth, but as soon as bigger objects (like Intrepid station) appear the game begins to stutter.
Ok, when I remember me playing WC4 back in 1997 on my P133 16MB, it never was totally smooth. Especially when flying in near or through big ships. Anyways... is there any opportunity to make the game faster? I mean, hey! I guess I still have a good system - even for the lame dosbox. 😉
2) The other problem is: Everytime my ship gets a hit (and because of the hit the ship's shield is flashing blue very short) the game becomes nearly unplayable. -> It seems like the framerate is dropping to nearly zero and I got huge graphic glitches. It's kinda like the short blue flashes of the blinkering shield remains on the screen and disapears only slowly by and by.
Sorry, it's not easy to discribe that for a non-native-speaking-english. 😉
Hoping that anybody out there knows a solution.
Regards!
Reply 1 of 18, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
The lame dosbox can use only one core for the major workload. And yes, there are strong reasons why that is so. If there is stuttering, most likely your fixed cycles are too high so decrease them.
About the other problem, try other output= settings.
1+1=10
Reply 2 of 18, by Drexciyan_Wavejumper
Hey, it wasn't my intention to diss the dosbox and/or it's makers. Sorry! 😀
I love the dosbox!!
Hm, new situation: I've installed the Daum Café one now. (the 3rd different dosbox on my system) It's the 05/19/2009 version from this page http://ykhwong.x-y.net/cvs/frame.html
No idea, what is different about that one. But now my problems within the flying part seem to be vanished completely. No graphic glitches anymore and the game is running pretty smooth now. (not perfect at all, but it feels like on my P133 back in the days, now) Btw: I assume that WC4 can't run totally smooth, when flying in near and especially through big ships, anyway. No matter how fast your system is.
Well, unfortunately the old WC4-stuttering-sound-within-the-videos-problem reappears.
And if I switch the cycles back to fixed and e.g. 30000 the videos are perfect, but then the flying part begins to stutter again.
Man, that is pretty annoying. Seems like there is no adjustment, that works perfect both for the video AND the gaming part... 🙁
Reply 4 of 18, by Drexciyan_Wavejumper
Yeah, that thought came into my mind, too.
Changing the cpu-cylces before and after every mission. I guess, that would be solution I can live with. Though it's not the perfect answer, cause there are also videos which occur immediatly while flying... But anyways, that will do...
The more important point is that my new usb-joystick, which I just purchased via ebay, will work together with WC4... (unfortunately my old and beloved MS Sidewinder Precision Pro (or better 3D Pro Plus) doesn't supports usb -> so I bid for the usb-version of it 😁 )
Reply 6 of 18, by Drexciyan_Wavejumper
I have a Sidewinder 3D Pro Plus. (but it was sold as a "Precision Pro" - it's virtually an "unreal" Precision Pro 😉 )
But it has only a gameport. And Vista doesn't support gameports - no way!!
Therefore I need a joystick with usb. (for playing WC4 on Vista via dosbox)
And because I don't wanna miss my beloved Sidewinder 3D Pro Plus, I purchased a Sidewinder Precision Pro via Ebay.
It's the same stick. The only difference is, that it has a gameport AND usb connection. (usb via adapter) It's a kind of newer version which includes the usb-technology.
Wiki can explain it better: For its electronics, the Precision Pro featured a refined hybrid system, resolving some of the hardware compatibility issues with the 3D Pro. However, with the widespread introduction of USB in consumer computers shortly after the Precision Pro was released, Microsoft soon re-released the joystick in a USB-compatible form (joysticks labeled as Part No. X03-57540, Product I.D. 85791-...[3]). The revised joystick still featured a gameport connector but had additional circuitry for interfacing with USB, and was bundled with a USB converter 😉
But, I just won the auction today. I don't have the Precision Pro, yet. So I don't know if it works together with dosbox and Wing Commander. (heard about calibration problems and stuff)
Reply 9 of 18, by Drexciyan_Wavejumper
Harekiet wrote:
I have a similar joystick that has both gameport and usb. Weird.
Yeah that's the one I bought recently. Just read my notes! 😉 😀
There are two versions of the Precision Pro. The old one, with only gameport connection. And this kind of reissue with both gameport and usb-technology. (and usb adapter)
Btw: Of course I could take your usb-adapter and connect it to my old Precision Pro (3D Pro Plus). It would fit mechanically, but it won't work, cause the older version doesn't contain the "additional circuitry for interfacing with USB". 😉
You must face the power of the black wave of Lardossa, before you can become a Drexciyan Wavejumper
Reply 11 of 18, by Drexciyan_Wavejumper
Really? How did you manage that??
It's a dos-only program and Vista hasn't got a dosbox like Win95/98.
I don't even thought about the opportunity to try it just under Vista... In my imagination it feels like if I'd put a vinyl record in a cd player and vice versa... 😉
Reply 12 of 18, by l_mcgregoruk
Well the version I have is a budget/re-release on EA CD-Rom Classics, which has both a windows client and a ms-dos client on 6 cd's, apparently origin later released a native-client for Windows/95.
Reply 13 of 18, by Drexciyan_Wavejumper
Ok, I got my original Precision Pro Joystick now.
Well, it seems to work, but there is only one problem: If I play WC4 via dosbox Daumcafé AND fullscreen, the game/dosbox always crashes if I press the fire button (no matter if I press it within the calibration screen or while flying).
If I play under ordinary dosbox 0.73 the game doesn't crash.
But I need that CVS build for smoother grahics!! 🙁
Any ideas, what could be the reason for my problem?
Reply 14 of 18, by DosFreak
Try changing output= in DOSBox 0.73.
We don't support the Daumcafe version here.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 15 of 18, by Drexciyan_Wavejumper
In Dosbox 0.73 the game doesn't crash, if I use the joystick.
But I just noticed another problem...
I used the keymapper (CTRL+F1) to add some former "keyboard-only"-keys to my joystick. E.g. stuff like change target, fire rockets (!), change weapons, afterburner etc. (I want to have as much keys/functions as possible on my stick).
But while flying I noticed that the remapping seems to be ended in a little mess.
I can't hold targets, if I simply shoot with joystick button 1, I also cycle the guns at the same time (therefore every single shot is shot by another gun etc.)
Within the Daumcafé version, I did not experienced that kind of problems. (the remapping seemed to work fine there) sorry 😉
Reply 16 of 18, by robertmo
check your autofire= setting
buttonwrap=false
joysticktype=ch
delete mapper.txt before every change you want to do to joystick.
Reply 18 of 18, by Drexciyan_Wavejumper
Thx in advance for the tips! 😀
I'll try 'em and give report later! 😉
