First post, by Myloch
- Member
this is a copy of the game I had from the 386sx era... and I clearly remember it worked without problems.
Unlike the version you find everywhere on the web (with car.exe and EGA only), in this one you run "carega" for ega, "carcga" for cga and "cartdy" for tandy. I tried it in dosbox and modern pc in dos mode this is not working. Can you test it yourself guys? Just for the curiosity if there is a way to correctly play it.
