First post, by TDDAD-OBI
Running windows 7, using Dosbox version .73
Trying to play Wing commander Armada. The game runs fine, as far as I can tell. However, the joystick seems to "lock" and get stuck in a position that I pull it to after a few seconds of use. No need to say, this kind of kills the game. It comes with a Joystick adjustment program, which never seems to work.
I use other joystick programs, and my joystick doesn't seem to have problems anywhere else. It might just be a problem with my download of Armada, but I'm wondering if anyone knows if Dosbox might mess up the joystick somehow.
Best wishes
TDDAD-OBI.
Reply 5 of 7, by TDDAD-OBI
The only thing mentioned in the manual is how to use the keyboard to simulate a joystick (Don't want to do) and how to switch around the axis (again, don't want to do). There is nothing mentioned in the manual about correcting for drift.
Reply 7 of 7, by ripa
How does one change Dosbox's joystick options?
Dosbox is configured by editing the <drumroll> configuration file. The manual (README.TXT) tells you how to edit and where to find the configuration file:
The file is divided into several sections (the names have [] around it). Some sections have options you can set. # and % indica […]
# and % indicate comment-lines.
The DOSBox configuration file contains the current settings.
DOSBox will parse configuration files that are specified with -conf. If none were specified it will try to load "dosbox.conf" f […]
none were specified it will try to load "dosbox.conf" from the local
directory. If there is none, DOSBox will load the user configuration
file. This file will be created if it doesn't exist. The file can be
found in ~/.dosbox (Linux) or "~/Library/Preferences" (MAC OS X).
Windows users should use the shortcuts in the startmenu to find it.
The config file has a section called [Joystick]. You can change joystick options there. The option you want to change is either joysticktype or timed. Changing timed to the other value (can't remember whether true or false is the default) will probably fix things. If it doesn't, change joysticktype to something else (probably 2axis - the drift might be caused by the extra axes).
Actually, there's this:
Q: The cursor always moves into one direction! A: See if it still happens if you disable the joystick emulation, set joystick […]
set joysticktype=none in the [joystick] section of your DOSBox
configuration file. Maybe also try unplugging any joystick/gamepad.
If you want to use the joystick in the game, try setting timed=false
and be sure to calibrate the joystick (both in your OS as well as
in the game or the game's setup program).
