First post, by bongazi
Hello,
how do I set a specific .conf file for all users that log onto the domain?
Currently the default .conf file is loaded but another user will not have the same configuration.
I want to do a all users startup link in windows 7 but it has to read the same configuration file for all users.
thanking in advance 😀
Reply 1 of 11, by DosFreak
Create a DOSBox folder in "C:\Users\All Users" and put a dosbox.conf in there. Verify all users have read access to it.
Point all shortcuts for DOSBox to that .conf.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 11, by bongazi
Hello,
Thank you for that -
how do i point the shortcuts for dosbox to that .conf ?
As very user that logs on and executes dosbox will have his
specific .conf file in
C:\Users\Administrator\AppData\Local\DOSBox
C:\Users\jwalker\AppData\Local\DOSBox
C:\Users\tgreen\AppData\Local\DOSBox
etc
regards
Reply 3 of 11, by Qbix
Rank DOSBox Author
DOSBox Author
you have to modify the shortcut to dosbox and add a -conf c:\users\all users\.....\configfile.conf
and hope it works.
DOSBox was designed to give each user its own configfile, so this is a bit of a hack.
Water flows down the stream
Reply 4 of 11, by bongazi
Hi Qbix,
thank you for your replies 😀
I tried to do that - if i right click the shortcut and do properties - the Target is: "C:\Program Files\DOSBox_MB5\dosbox.exe" -conf c:/rs-prodo/dosbox.conf
but it still loads the C:\Users\Administrator\AppData\Local\DOSBox config file.....
any ideas 😢
Reply 5 of 11, by DosFreak
Are you sure there is a dosbox.conf in c:\rs-prodo ?
Reply 6 of 11, by bongazi
DosFreak & Qbix
... I am so deeply sorry for wasting your time with my own stupidity... 😊 ...
there is a dosbox.conf file in that folder ... but it is a
dosbox.conf.txt ... and I just saw that after this " Are you sure there is a dosbox.conf in c:\rs-prodo ?" was posted.
I fixed that and it it working PERFECTLY !!!
thank you again for all your help and time... 😁
regards from NAMIBIA !!
Reply 7 of 11, by bongazi
Hello - again 😊
is it possible to have only one instance of dosbox running on a win7
machine? Is it something I could add to the config file?
Because when I switch users i am able to start the same abbplication for other users - this might corrupt my data...
thank you
Reply 8 of 11, by DosFreak
Yeah that isn't your fault actually. Stupid windows hides the extension. 😠
Reply 9 of 11, by DosFreak
bongazi wrote:
Hello - again :blush: […]
Hello - again 😊
thank you
You'd have to modify the DOSBox code to do so. If you can't do that or get someone to do it for you then you'll just have to turn off user switching.
Reply 10 of 11, by bongazi
Thank you DosFreak,
i will start dosbox with a batch file that looks like this:
tasklist /FI "IMAGENAME eq dosbox.exe" 2>NUL | find /I /N "dosbox.exe">NUL
if "%ERRORLEVEL%"=="0" echo Early Warning System is already running...
if "%ERRORLEVEL%"=="1" "C:\Program Files\DOSBox_MB5\dosbox.exe" -noconsole -conf c:/rs-prodo/dosbox.conf
I am just unable to get dosbox up with -noconsole...
any ideas..?
regards.
Reply 11 of 11, by bongazi
Hello,
I managed to get thing going using this batch:
@echo off
if "%ERRORLEVEL%"=="0" msg %username% Electronic Early Warning Sytem Already Running. Click OK.
if "%ERRORLEVEL%"=="1" msg %username% Electronic Early Warning System Monitoring Started %date% %time%. DO NOT close the monitoring window. Click OK to Proceed.|"C:\Program Files\DOSBox_MB5\dosbox.exe" -noconsole -conf c:/rs-prodo/dosbox.conf | taskkill /F /IM "cmd.exe"
hope this can help someone - To the others, thank you for your much needed help - an a big thank you to the creators of DosBox and DosBox MB5. You guys are great!
Regards,
Bongazi
