First post, by VampireSilence
hi guys,
i got problems starting clash 95 on dosbox. additionally the game is a polish version, so its hard to understand the thrown errors. if i translate it right it says "configuration file could not be found" (when i try to start it). setup worked fine cause its for dos/95 but im running it on XP so it wont start on its usual way.
im using the ampshell gui but it throws this error anyway. can you help me ?
regards
- VampireSilence
Reply 2 of 5, by VampireSilence
yes i did but 98se/me/dos nothing worked so dosbox is my last hope.
i know that others have successfully emulated clash on dosbox so i hope i can do it too. the only problem is that configuration file..
Reply 3 of 5, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
post your mount lines and what is written under every mount line
post what is written after you type "mount"
Reply 4 of 5, by VampireSilence
DOSBox Version: 0.74 from www.dosbox.com
AmpShell Version: 1.1.2.7 from ampshell.tuxfamily.org
OS: Windows XP
CPU: AMD Turion(tm) 64 X2 Mobile (Technology TL-50) 1,61 GHz Duo Core
RAM: 2 GB Aeneon
Content of DOSBox:
DOSBox version 0.74
Copyright 2002-2010 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\LONGSOFT\CLASH/dosbox-0.74.c
onf
MIDI:Opened device:win32
DOS keyboard layout loaded with main language code GR for layout gr
DOSBox switched to max cycles, because of the setting: cycles=auto. If the game
runs too fast try a fixed cycles amount in DOSBox's options.
Configuration file:
[sdl]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper-0.74.map
usescancodes=true
[dosbox]
language=
machine=svga_s3
captures=capture
memsize=16
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=auto
cputype=auto
cycles=auto
cycleup=10
cycledown=20
[mixer]
nosound=false
rate=44100
blocksize=1024
prebuffer=20
[midi]
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=7
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[gus]
gus=false
gusrate=44100
gusbase=240
gusirq=5
gusdma=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=44100
tandy=auto
tandyrate=44100
disney=true
[joystick]
joysticktype=auto
timed=true
autofire=false
swap34=false
buttonwrap=false
[serial]
serial1=dummy
serial2=dummy
serial3=disabled
serial4=disabled
[dos]
xms=true
ems=true
umb=true
keyboardlayout=auto
[ipx]
ipx=false
[autoexec]
(avoided #-lines)
Mount:
Drive C: C:\Longsoft\Clash
Drive Z: Internal Virtual Drive
(no additional mount lines)
hope this helps you to help me..
