First post, by Sieg
Howdy.
I've got a small problem with Monolith's Blood on Dosbox. I'll make the rounds and fill in the list from this forum as best I can.
  • 1 Motherboard - Can't remember, sorry.
    2 Processor type and speed - Intel Core 2 Quad Q95500 2.83 GHz
    3 Amount and type of RAM - Not sure on type, 3.25 GB (4GB)
    4 Video board w/ RAM amount and type - Radeon 4870 1GB
    5 Sound board - Just your average onboard job
    6 Operating system - Windows XP SP 3
    7 Game name (and version, if applicable) - Blood, 1.21 OUWB
    8 Description of problem (be detailed: saying "it's jerky" doesn't help, saying "the player sprites seem to be jerky when I'm pressing any of the arrow keys" does) - See below
    9 Reproducibility of problem (always, only once, always but only on a specific level, etc.) - See below
    10 Sound mode used - sblaster
    11 Video mode (Software, OpenGL, Direct3D, or Glide, and resolution) - overlay. Odd, I thought I'd changed it to opengl. Trying for 800x600
    12 Version of emulator (for VDMSound, probably 2.0.4 or 2.1.0; for DOSBox, 0.58+) - Dosbox 0.74
    13 Steps already attempted to solve the problem (please say you've read the README if you haven't, and READ IT IF YOU HAVEN'T!) - I've read the readme...
Hopefully the techies of the board can help me out of this. With a bit of luck, maybe this will assist other people in beating this problem.
Long story short, I've tinkered around a bit with Visual Studio in the past and because I tend to veer towards older games and aim for widescreen support in them, I've often hit a few speedbumps on the way. I've noticed that since the installation of Visual Studio the crashing for most anything has resulted in a window with some message about a JIT compiler and it offers me the unique opportunity to debug the problem. Great.
Perhaps it's nothing, but I could swear that the presence of Visual Studio seemed to encourage errors of this sort, though don't take that as a sign that the machine's faulty, as I can run a handful of things without a blip for days.
Yes, that's the short version.
Now, all was fine and dandy until Dosbox 0.74's release. I could run Blood with impunity, but upon running Blood in Dosbox 0.74, I am greeted with this message after about ten or so minutes of play. This problem repeats.
In a brazen effort to combat this, I actually deleted my Visual Studio, but to no avail; the problem persists in the form you see above.
Any assistance or direction would be appreciated!
P.S. Reverting to a previous Dosbox version is not desirable, as Blood receives a notable performance boost with the upgrade.
P.P.S. I am actually willing to format the machine in an effort to alleviate this, but I'm hoping that's a last resort.
P.P.P.S. Not playing Blood is not an option.
Take care, everyone!
Defend what's yours.
Reply 1 of 5, by DosFreak
Found this: http://social.msdn.microsoft.com/forums/en-US … 8-e521e13260ff/
Seems like a fun page with tons of things to try.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 5, by wd
Rank DOSBox Author
DOSBox Author
Maybe first try limiting it somehow, like disable sound, use the standard
320x200/320x240 video mode, try a different output= setting in your
dosbox config file and things like that.
Reply 3 of 5, by Sieg
This bug's been busted.
The hint towards the solution was in fact within my original post. The [sdl] output section was set to overlay. A simple tweak to Opengl has toppled this issue. So, while I stand humbled in the light that it was a fairly simple solution, which I even deleted my Visual Studio over, I am relieved that it is cured and this will all have been worth it if my thread here assists at least one fine fellow in the future. I leave the thread's fate to the moderation team.
Thank you to those who took the time to read and especially you two who replied. Seems your advice was sound DosFreak, but it combatted only a symptom of a greater foolishness on my part. Wd, I smiled at seeing that your solution would've eventually led to overcoming the problem.
A fairly mundane solution after all and perhaps not at all exclusive to 0.74. Thank you and farewell!
