First post, by vorob
Hi, i've got one one game from my childhood, Wrath Of Earth. I had this problem before, in 1996 and i have it now (lol), when i'm trying to play it via dosbox i've got this error message:
What do i need to change in dosbox.conf to fix this issue?
Reply 3 of 11, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Try different output options in the dosbox config.
Moved to the dosbox forums. When your question concerns dosbox, use the dosbox forum, please
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 11, by Dominus
DOSBox Moderator
And the others? Also please try dosbox 0.74, not only a build by Ykhwong or others with multiple patches that might pose a problem.
Reply 7 of 11, by Dominus
DOSBox Moderator
Don't know but the installer is harmless
Reply 10 of 11, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Use fixed cycles of around 10K (cycles=10000) to avoid flickering, and the FM music will work more reliably with that setting as well. WoE uses a 320x240 video mode with square pixels that don't need aspect correction, and enabling aspect correction in DOSBox 0.74 will cause the display to be slightly blurred, so I suggest the aspect=false setting for this particular game.
Reply 11 of 11, by vorob
Thx. Btw, any way to know what cycle number will be ok for specific game before i start? Maybe there is a way to calculate this?
