First post, by red_avatar
I have:
XP 2500+
1Gb DDR 400
Radeon 9800 Pro
SB Audigy 2
WinXP
When trying to run C&C, I get an error saying it can't find the CD. I tried the following line:
mount d: h:/ -t cdrom -ioctl -label GDI
But it won't work ... any ideas ? I got similar problems with LBA2 and other friends have them with other games.
I use Dosbox 6.1 BTW
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
it's dosbox 0.61
there is no need to call it 6.1 as certain software companies might do.
XP.. are you being an admistrator or not ?
try for a change the -usecd option (not combined with ioctl)
Both games (as rips) work fine.
CDrom... still a hard one (to do that cross-platform )
Water flows down the stream
