First post, by Ariadne
Can anyone advise whether the Psion 2 Emulator software will run in DOSBox on a Windows 10 64-bit PC. I cannot get it to work.
The emulator software can be downloaded from
https://1drv.ms/f/s!Ag8aQ52IE8ZphSA96VTmeO61oiYB
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Yes, the emulator software works in DOSBox 0.74-2 and SVN with default settings; however, it needs ROM images for the emulated device.
You can find both the emulator software and the ROM images on the author's website via the Web Archive: http://web.archive.org/web/19990427201447/htt … onorg/index.htm
The emulator author claims the device manufacturer gave permission for the ROM images to be distributed. Whether or not that is true, or still true today, is not certain -- use the ROM images at your own discretion.
