First post, by Jo22
- l33t++
Hi everyone, Not sure if that's the right place, but i would like to ask if Sound Blaster 16 emulation now works for IT.
- Running Impulse Tracker with the command line parameters "IT S2" (SB1), "IT S3" (SB2) and "IT S4" (SB Pro) works, but not "IT S5" (SB16).
While the SB16 driver (non-MMX) of Impulse Tracker loads fine, the Tracker seems to refuse to play anything.
Anyway, I'm just curious. The program might also run under virtualization, even though not as stable as under DOSBox. 🙁
I'm using DOSBox 0.74-2 (Win32) from dosbox.com .
PC is AMD Athlon 64 X2 4000 (Brisbane core), running Windows 7 x64,
