First post, by inukaze
Hi there i am trying to install dungeon keeper from bin/cue
when i mount and launch the setup program i can't see text.
Someone can explainme if this is a bug of dosbox or from my disc ?
Dosbox 0.74-3 [Devuan ASCII / Debian Stretch]
Same result on Slackware 14.2 & Slackware64 14.2
Reply 1 of 2, by inukaze
Well meanwhile i had solved using QEMU.
The first thing i download the HDD 512 Image from HERE
after of that i mount with the follow commands
[code]mkdir -p /tmp/hdd-512mb
sudo mount -o loop,offset=32256,uid=1000,gid=1000 ~/hdd-512mb.img /tmp/hdd-512mb[/code]
i install and use KVM, QEMU & AQEMU for install & Configure MS-Dos 6.22 and a second image file for the dungeon keeper cd data, but like hdd. because i don't know why qemu don't mount cdrom under msdos 6.22. and i use the commands inside Qemu + Msdos 6.22
[code]d:
cd keeper
cd dossetup
setup[/code]
Screenshoots [Spanish Text, because i am from venezuela and the spanish is my native language], Setup & Install :
dngkpr01.pngdngkpr02.pngdngkpr03.pngdngkpr04.pngdngkpr05.pngdngkpr06.pngdngkpr07.pngdngkpr08.pngdngkpr09.pngdngkpr10.pngdngkpr11.pngdngkpr12.pngdngkpr13.pngdngkpr14.pngI had installed on D:\JUEGOS\DNGKPR and i had test the game can start perfectly normally
Well i hope found a solution for make the installation from dosbox. by the moment i just copy this installation to the path i need and modify the keeper.cfg file to adapt the path.
Reply 2 of 2, by Akuma
149.46 KiB
167.79 KiB
Works fine here 0.74-4.3, cdrom might be scratched or dirty when the image was made.
