First post, by khfpl
I am running DOSBox on my Macbook in order to use a very old database program (WordPerfect's DataPerfect), a very powerful database engine which - today - is public domain software.
I could setup DOSBox without any problem, DP is (in principle) running fine, but in order to create a new database and specifically the 'define index' function I'd need to use control+F8, but this doesn't work. All other F-Keys work just fine (F-Key, Alt+F-Key, SHIFT+F-Key, CTRL+F-Key).
I believe that maybe Keymapper (DOSBox) may be helpful, but I cannot start this (CTRL+F1 as described in the DOSBox manual).
Any idea?
thanks
KHFPL
