Reply 41700 of 44668, by Kahenraz
- l33t
retrogamerguy1997 wrote on 2021-12-27, 22:14:TrashPanda wrote on 2021-12-27, 21:22:IIRC the MX4000 was the replacement for the MX440, the 4000 being the newer of the two. […]
retrogamerguy1997 wrote on 2021-12-27, 19:46:Bought this as an upgrade over my MX4000: https://www.ebay.com/itm/334261306195
Still waiting for my socket a cooler to arrive.
They are similar in spec but the 440 does have faster Vram and a wider bus ... but the trade off is that it has less Vram overall.
Looking at them both I would have just grabbed a Ti4200 and gotten pixel shading but I cant fault the price of 20 bucks for a MX440, thats a nice deal no matter the reason for using one.
damn, I got it based off of other people's advice here. Then again I'm sure I would still see a benefit since my mx4000 is pci and 64mb
Some people's advice here is also... not wrong but incomplete. Depending on what hardware and OS you're using, a GeForce 4 could be unstable. For example, NVIDIA cards with pixel shaders require at least a Pentium 3 Coppermine, have problems in Windows 98 with some configurations, and other issues with chipsets prior to 440BX. Everything non-pixel shader such as the card you bought should work great. Maybe. Unless it requires +3.3V on PCI and your board doesn't have that.
There is no right answer, unfortunately. 😀
