Reply 43560 of 45407, by Tetrium
HanJammer wrote on 2022-03-28, 20:59:
These 30-pin simm modules.
I have seen similar SIMMs in the past, but not like this with a double row xD
Very impressive.
cyclone3d wrote on 2022-03-29, 00:32:
So you are the one that won the eBay auction.
I was kinda wanting them for the lulz.
I can imagine this for sure 🙂
My retro rigs (old topic)
Report spammers here!
Reply 43561 of 45407, by HanJammer
I will use them in some outrageous 386/486 build on my channel.
Want to buy AT cases, motherboards and other vintage stuff? My Items for Sale
Reply 43562 of 45407, by Cuttoon
Areca ARC-1160 S-ATA RAID controller.
PCI-X with 16 channels.
At least the great aunt of all RAID controllers.
CPU is an SL9BE Intel 80331 ARM-based I/O processor.
(Had to pry the lens off my SLR to be able to read that...)
512 MB cache memory, so German, it is Swiss.
Not sure what the RJ45 on the backplate was supposed to do.
Also, rather uneventful "Prolink NVG11A" Gf2 MX-400 with Chrontel TV chip and native s-video port. Bent, but unbroken.
94.01 KiB
92.31 KiB
301.08 KiB
I like jumpers.
Reply 43563 of 45407, by ChrisK
Could add these:
1.73 MiB
Of course double sided 😉
Reply 43564 of 45407, by Tetrium
ChrisK wrote on 2022-03-29, 12:30:
Could add these: IMG_20220329_142704.jpg Of course double sided ;) […]
Could add these:
and these
161.3 KiB
Most (if not all) are also double sided. Pic was taken years ago.
Of course these aren't 30p, alas 🤣
But I think HanJammer's modules are the most epic looking ones! 😜
Reply 43565 of 45407, by Radical Vision
Could add these:
Wtf one of these modules is 16MB 🤣...
Jesus insane server grade memory... Best i have seens here are EDO 72 pin 64MB, my best sticks are 32MB Siemens... And the 128MB Compaq EDO DIMM, but that is another thing, they have prob up to 512MB and maybe even 1GB per module...
R7 3700x/ Aorus x370 K7/ RX 6800XT/ X-Fi THD
K7 2.6/ NF7-S V2/ HD3850/ X-Fi
IBM x2 P3 1.4/ DX34R-U/Voodoo V 5.5k/ Audigy
IBM PC365 S8
Compaq DeskPro 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 43566 of 45407, by HanJammer
Could add these:
Yeah, I have modules like these and similar ones in both SIMM and DIMM form factor. They are pretty common. Some sitting around my desk right now:
Reply 43567 of 45407, by imi
I got these "tetris-blocks" a while ago x3... definitely the weirdest 30pin modules I have
254.63 KiB
Reply 43568 of 45407, by weedeewee
talking about 30p simms ...
yes, they're double sided
imi, time to build a tetris pc !
Do not ask Why !
Reply 43569 of 45407, by Kahenraz
I don't have any Tetris blocks to add, but I do have one of these. I feel like all of the nonsense of these huge memory "sticks" is from manufacturers trying to find clever ways to get rid of their old stock of chips. No one will ever see it inside the computer anyways, right?
168.68 KiB
Reply 43570 of 45407, by HanJammer
imi wrote on 2022-03-29, 15:25:
Nice, perfect for AWE32 too ;D
Reply 43575 of 45407, by Big Pink
99p for this Compaq motherboard from, it appears after a lot of searches, a ProLiant ML350 G2. I was kind of hoping the bottom slot was EISA but it turns out it's for the 'Feature Board'. Dual Tualatin capable! Now if I only two Tualatin CPUs. Or even one.
    421.09 KiB
    Seller's photo.
I thought IBM was born with the world
Reply 43576 of 45407, by Radical Vision
Big Pink wrote on 2022-03-29, 18:02:
Sadly that bottom slot is brown, not black and is not ISA it is clear... And you wont be able to run dual CPUs as well, unless you find the VRM module... Also if you dont have the proper Compaq PSU the board is useless... Hate that crap, my Compaq AP550 Pro came without the PSU, and is some special 20 pins + 6 pins...
Now when i did look more at that pic the VRM slots are 2 🤣... That prob means the board wont work at all unless there is one VRM installed...
Damn these modules and budget crap from OEMs...
IBM PC365 S8
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 43577 of 45407, by Big Pink
Yeah I know about the VRMs, although they're pretty cheap. I figured the PSU was proprietary at least in part with the extra input header.
Reply 43578 of 45407, by Solo761
Not much today, only ALS100+ ISA sound card for 486 that's on the menu to be built next.
331 KiB
Reply 43579 of 45407, by flupke11
Got 2 velociraptors, 500GB each for under 16 euro. Never knew they made them this large. I have two 74GB, two 150's and 2 300's now.
Why not start a collection 😀
