Reply 24560 of 52352, by stamasd
wrote:I was just guessing, TBH. The only other place I've seen the kind of connector that's above the memory slots is on certain Japanese systems where the motherboard is basically build out of modules that can be swapped for different configurations.
I was talking about the square PGA142 socket, not the NuBus-like slot connector.
What would be the use for a co-processor on a system that already uses a DX processor?
The Weitek works in a completely different manner from the internal FPU; there were some programs optimized for the Weitek that didn't run so well on the regular FPU. Yes it's an oddity but not absurd.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
