Reply 33040 of 34202, by imi
LewisRaz wrote on 2020-03-17, 20:29:
Well my new 486 Arrived today. […]
Completely gutted.
PC was packed alright, not amazing but would not have expected this amount of damage after I opened it.
Somehow, after replacing the broken jumpers, bending pins back and crossing my fingers.. It actually boots.
bummer, glad to see it still work though 😀
got to sort out a few more things...
Diamond Stealth VRAM with missing bracket 🙁 and Diamond Stealth 24
453.2 KiB
miro 20SV S3 Vision968, this one is of significance to me because I got the same one in my 1996 rig way back and now I finally got one again 😀
and another Riva128, these seem to pop up in every other lot I manage to get lately x3
also another V7 Mirage P-64 S3 Vision 864
342.45 KiB
Number Nine S3 Savage4 LT, Tseng ET4000/W32p (the layout on this one seems backwards?)
one more MPEG-2 card CT7260
477.1 KiB
now that's one long AGP card...
Evans & Sutherland REALimage 2100
unfortunately also missing the bracket and it's a bit beat up, wondering if I'll get this one to work ^^
242.31 KiB
rather big ESS ES688FC with OPL clone and a rather curious Aztech "Sound Galaxy Business Audio 16" without gamport but a "phone" connection ^^
671.53 KiB
Reply 33041 of 34202, by Almoststew1990
I bought an AGP 7600GS today which hopefully will bridge the gap between my GeForce 3 ti 200 and more modern PCIE cards, and used for games in the 2003 to 2005 range with a Pentium 4 or something.
Ryzen 3700X | 16GB 3600MHz RAM | Nvidia GeForce 1070ti | 1Tb NVME SSD | Windows 10
Athlon 3200+ @ 3800+ (Venice) | Some Ram | Nvidia GeForce GTX645 / 7950GT
Slot 1 896MHz | 384Mb 112MHz RAM | Nvidia GeForce 3 ti200 | AWE32
Reply 33042 of 34202, by Horun
Completely gutted.
It has taken one hell of a shunt to bend thick steel like that!!!
The floppy drive is a right off.
The HDD/floppy cage will need some bending to make it fit again.
The case is cracked and that bend underneath it seems very difficult to correct.
Several jumpers on the motherboard have taken such a hit that they fell to pieces.
The CPU was hit so hard it took the fan off of the heatsink(4 screws!!) and the CPU had even started to lift from the socket.
The soundcard was hit and broke some superficial plastic from the ISA slot.
It took me a while to come to terms with it and slowly take it apart and assess each part.
Once I am over my dissapointment of this damage I will share the insides as there is actually some nice parts inside.
WOW they must have dropped it off the delivery truck. Good to hear the board works.
Hate posting a reply and have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor. 🤣
Reply 33043 of 34202, by pewpewpew
Almoststew1990 wrote on 2020-03-17, 23:36:
That sounds right to me. I use a 7600GS on ASUS P4P800SE 3.00GHz .
Reply 33044 of 34202, by dionb
Just received this beauty today:
165.69 KiB
Looks pristine, but untested by last owner due to not being able to find a suitable CPU. That's not going to be easy, but challenge accepted 😀
(that's a Socket 413...)
Reply 33045 of 34202, by jaZz_KCS
dionb wrote on 2020-03-18, 13:20:
Just received this beauty today: 15845370400300.jpg […]
Mmh, PCIX.
What are your plans for the machine?
Reply 33046 of 34202, by dionb
jaZz_KCS wrote on 2020-03-18, 13:41:
Mmh, PCIX.
No PCI-X, that's just regular 64b 5V PCI.
Plans? Get it working, that would be cool enough. Run Win2kRC2 because I can- then install something else because no software for the platform 😜
Reply 33047 of 34202, by EvieSigma
When I try to Google for it I can't even find a Socket 413. Is this a non-x86 board or something?
Reply 33049 of 34202, by dionb
EvieSigma wrote on 2020-03-18, 14:11:
Yes. It's a Digital AlphaPC 164LX board, and it accepts AXP21164PC CPUs (400 or 533MHz).
They're not expensive, but very rarely come up for sale. Last one was one on CPU-world for USD 15 last Autumn.
derSammler wrote on 2020-03-18, 14:19:
It's called Socket FT1, or BGA413.
Er no, this is definitely for PGA CPUs, not BGA. Also about 14 years older.
Reply 33050 of 34202, by EvieSigma
dionb wrote on 2020-03-18, 14:26:
Yes. It's a Digital AlphaPC 164LX board, and it accepts AXP21164PC CPUs (400 or 533MHz). […]
I had a feeling it was Alpha. Alpha hardware is still somehow in regular business use so finding it on the secondary market isn't the easiest.
Reply 33052 of 34202, by texterted
Today's project.
A Radeon 9500 vanilla. It has the L shaped memory chip arrangement on the card.
These can, often times, be soft-modded with the Omega drivers, into a full fat 9700 with all the pipelines unlocked.
This was a success with this card and of course, I removed the stock cooler and that bloody die shim! I had to soak that yellow thermal cement they used in WD40 for quite a while before I could remove the shite. WTF?
Anyway, stuck on one of those cheap Chinesium vga coolers on there. They work a treat and are inexpensive. A vast improvement over stock. I'll stick some ram-sinks on if postie ever brings them.
159.26 KiB
90.39 KiB
Cheers
Ted
98se:- Gigabyte GA-6BXE, PIII 700, 256 mb sd ram, Rage 128 Pro. Ensoniq PCI Audio.
98se:- Asus A8v Dlx. A-64 3800+, 1024 mb ddr, Nvidia 6600GT 128 MB. SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 33053 of 34202, by LewisRaz
Cleaned up the new case today. Not too bad now! Going to have to glue the 3.5" drive cover in as the plastic catch has snapped. Need to get a spare floppy out of the loft too. This system happily recognises my IDE-CF with 1gb card in so thats a bonus.
Also attached some of the internals that came with the machine.
    269.59 KiB
    375.56 KiB
    607.09 KiB
    437.84 KiB
    480.41 KiB
Reply 33054 of 34202, by piatd
Munx wrote on 2020-03-16, 08:32:
The flea markets I go to will be closed for a couple weeks due to the outbreak, but this weekend I still managed to get a few go […]
The flea markets I go to will be closed for a couple weeks due to the outbreak, but this weekend I still managed to get a few good items that will keep me entertained during that time:
Looks like the younger cousin of an Inwin S500. Is this an actual Inwin case or a clone?
Reply 33055 of 34202, by Horun
wiretap wrote on 2020-03-18, 18:12:
CT1350B for $9 shipped. […]
Wow good price ! Hope it works
Reply 33056 of 34202, by Horun
LewisRaz wrote on 2020-03-18, 22:29:
Nice ! Good looking case. I have one of those 30pin to 72pin adapters from back the 90's.
Reply 33057 of 34202, by Munx
piatd wrote on 2020-03-19, 00:59:
Don't know, I could not find any markings on or in the case.
My builds!
The Underdog - The budget K6
Reply 33059 of 34202, by liqmat
imi wrote on 2020-03-19, 12:21:
got some cpu trays... 🙁
Good lord man, I hope you're not split on whether to contact the seller for a refund.
