Reply 33680 of 52691, by seanneko
Picked up an Intergraph Intense 3D, a pretty early OpenGL workstation card. It gets a whopping 1 frame every 10 seconds in Quake 3 (with all the settings maxed out).
How does it do on q1 with low resolutions?
pentiumspeed wrote on 2020-05-01, 01:31:mpe wrote on 2020-04-30, 18:44:2nd dual P90 430NX Neptune motherboard:
The "dual CPU pentium board", Note the extra pin on the non-ZIF socket. I think this is really a cache controller.
That's no extra pin. That's D42. It stands out as there are other VCC and VSS pins missing in the E-row compared to Socket 5. But that pretty much copies the CPU pinout.
Cache controller on 430NX would be weird as there is already one in the chipset.
Daniël Oosterhuis wrote on 2020-04-30, 18:25:Got some more hardware today. Got this really nice Highscreen ATX (with removable standoffs for both AT and ATX) Miditower for € […]
Got some more hardware today. Got this really nice Highscreen ATX (with removable standoffs for both AT and ATX) Miditower for €10, which will likely house an Epox EP58-MVP3C-M Pentium 233MMX (OC @300MHz) system that's currently in another AT case. I'll see about having an AT I/O shield printed for it. It is missing the power button (the physical switch, not the plastic bit and spring), and the USB port behind the cover, but that should be relatively easy to fix. (Just using the seller's picture, by the way)
Interesting, I had this exact PC in October 1997 (Vobis Highscreen XI Allround 233). It came factory equipped with a FIC PA-2010+, Pentium MMX 233, 32 MB SD-RAM, 2 GB HDD, ATI Mach 64 2 MB, 24x CD drive (Teac CD-524EA). OS not included. Price: 999 DM. I loved the USB 1.1 port at the front, this design was at least 2-3 years ahead of its time back then.
OK, so like in the picture, you have now 128kB cache (2 data chips too much but that should not hurt), and it works ok? As shown in the picture, you have set the cache size correctly to 128k
Is this correct?
Just to be sure. Did you set the cache size to 256kB, when you put in all 8 data chips?
Chaintech 6VJD, my first VIA DDR PIII mainboard. I think I have now the whole collection of PIII chipsets. This boy will be added to the Tualatin chipset competition Pt II.
An QU37ES Xeon PIII 700/1M on 2,8V.
4 Golden Orb knockoffs (one pictured), but they look too similar to have been made outside the same factory.
2 Thermaltake Blue Orbs NB coolers (one pictured).
all NOS, apart from the Xeon.
cards cards cards!
these were part of the big lot recently from 3 different auctions... even though these were sold as scrap, I kindly asked the seller to pack them well and they were, all in pretty good condition too.
a few sound cards, and I think the first CT1350B with CT1366 and not CT1366A that I got.
Creative Graphics Blaster Riva TNT CT6710, Hercules 3D Prophet 4000XT, Kyro with PCI :3
another Diamond Riva128 AGP and ELSA Riva128 AGP
Alliance ProMotion-AT3D card, this seems to be a somewhat odd card with totally broken 3D, but 100Mhz RAM
see: https://www.youtube.com/watch?list=PLOeoPVvEK … a&v=GM8nZKojHds
Creative 3D Blaster Banshee CT6750, Voodoo Banshee with 16MB SGRAM :3
the recently mentioned SPEA Mirage P64V Turbo, S3 Vision868 with faster RAM
and a Geforce 6600
more S3 Cards... I didn't know AdLib made graphics cards? "AdLib Genesis 765" Trio64V+
Diamond Stealth SE, Trio32
miro Crystal 20SD, Vision864
ELSA Winner 2000AVI-4, Vision968 with 4MB
and more S3 cards... SPEA V7-Mirage P64 Trio64, miro Video22SD Trio64V+
a generic S3 Trio64 and another Matrox Mystique 220
there were a few other sound cards and I/O cards included... unfortunately the QuickJoy dual gameport card from the sellers pictures seems to be missing 😒
imi wrote on 2020-05-01, 10:50:cards cards cards! […]
cards cards cards!
... the recently mentioned SPEA Mirage P64V Turbo, S3 Vision868 with faster RAM
a generic S3 Trio64...
You can never have too many S3 cards 😆
CoffeeOne wrote on 2020-05-01, 09:09:OK, so like in the picture, you have now 128kB cache (2 data chips too much but that should not hurt), and it works ok? As shown in the picture, you have set the cache size correctly to 128k
Is this correct?Just to be sure. Did you set the cache size to 256kB, when you put in all 8 data chips?
Yeah, when all 8 are populated I set it to 256kb.
Going with your suggested configuration for 128kb, so the first 4 populated and the last 4 empty, plus the tag, I get no error, but Phil’s software also doesn’t detect any L2 Cache.
I don’t know enough about how those L2 cache sockets are linked, as I haven’t looked at any diagrams, however I’m guessing they are interconnected in series. I’m sure many on here know the details.
Because it’s banks 0&1, I suspect that when they aren’t populated due to the suggested manufacturers suggested layout, Cache won’t be detected as the series is broken. However if I populate those 2, or even just one, it’s seeing something but there is a physical problem with the electrical tracing on some pins causing the link to break.
I have a multi metre I can test the pins with, and bounced some questions off my father who’s an electronics technician, but even still this seems like a lot more work than I want to get into for 2 reasons. The first even if I do isolate a broken trace I can’t fix it, and two all the time I’m investing in this board, it’s still a VLB’less and PCI’less board.
Thanks for the all the suggestions however, much appreciated.
dave343 wrote on 2020-05-01, 11:52:Yeah, when all 8 are populated I set it to 256kb. Going with your suggested configuration for 128kb, so the first 4 populated an […]
Going with your suggested configuration for 128kb, so the first 4 populated and the last 4 empty, plus the tag, I get no error, but Phil’s software also doesn’t detect any L2 Cache.I don’t know enough about how those L2 cache sockets are linked, as I haven’t looked at any diagrams, however I’m guessing they are interconnected in series. I’m sure many on here know the details.
Because it’s banks 0&1, I suspect that when they aren’t populated due to the suggested manufacturers suggested layout, Cache won’t be detected as the series is broken. However if I populate those 2, or even just one, it’s seeing something but there is a physical problem with the electrical tracing on some pins causing the link to break.I have a multi metre I can test the pins with, and bounced some questions off my father who’s an electronics technician, but even still this seems like a lot more work than I want to get into for 2 reasons. The first even if I do isolate a broken trace I can’t fix it, and two all the time I’m investing in this board, it’s still a VLB’less and PCI’less board.
For 128kb populate the 4 with the writing bank 0 only.
I hate to admit this but I had a similar cache problem and it turned out that it needed to be enabled in the bios as well
LewisRaz wrote on 2020-05-01, 12:59:I hate to admit this but I had a similar cache problem and it turned out that it needed to be enabled in the bios as well
It’s definitely enabled in the bios
boards boards boards!
...part 2 of the big "scrap" lot
ASUS TXP4-X socket 7 ATX, FIC PA-2002 socket 7
FIC PA-2000 socket 5, Intel Tahiti socket 5
Gigabyte GA-586ATV socket 7, Gigabyte GA-5AA SS7 with a bit of dirt
ASUS P/I-P55TP4XE socket 7, Soyo SY-5EH5 socket 7
MSI MS6117 440LX Slot 1, Commate? K7TA KT133 Socket A with ISA
FIC 486-PIO2 VIA 496/505 socket 3, unknown 486 ISA board ever so slight surface corrosion on the KB connector, going to get the snip ASAP
Peacock? PCK 486 DX, Biostar MB-8433UUD-A socket 3
BC3486UL, supposedly Opti Local Bus... slight corrosion on the battery, board is clean, snip snip
Chaintech 486SPM socket 3, same as above slight corrosion on the battery, board still clean
and the two more problematic ones...
Hyundai branded Gigabyte GA-486VS, heavily corroded 😒
and an unkown "MB456"? heavy corrosion on the battery and some on the ISA, board looks mostly OK but traces in the battery area might need some repair.
darry wrote on 2020-05-01, 15:39:Refurbished U2412M, an affordable 1920x1200 LED backlit monitor that can handle 1600x1200 without stretching, if I did my research right .
I use that one on my daily driver, in my mind it's still new... Glad to hear it also has retro qualities... 😀
1982 to 2001
imi wrote on 2020-05-01, 15:53:boards boards boards! […]
hardware38_32.jpgGigabyte GA-586ATV socket 7, Gigabyte GA-5AA SS7 with a bit of dirt
hardware38_33.jpgMSI MS6117 440LX Slot 1, Commate? K7TA KT133 Socket A with ISA
hardware38_34.jpgFIC 486-PIO2 VIA 496/505 socket 3, unknown 486 ISA board ever so slight surface corrosion on the KB connector, going to get the snip ASAP
hardware38_35.jpgBC3486UL, supposedly Opti Local Bus... slight corrosion on the battery, board is clean, snip snip
What a haul!
This week I purchased an entire PC which turned out to have a broken motherboard. Dissapointing but I did get a case that will be very useful to me(with psu, 2xhdd and 2xcd) as well as a soundcard, videocard and not pictured 2x 32MB 72pin ram sticks.
imi, where do you store so many boards if I may ask? I have around 20 and they take up so much space I find myself having to sell inferior options whenever I come across something more premium.. It's the one thing I can't really 'hoard' many of, they take up so much space!
I recently ordered another ~650 shielded bags of all sizes, now I finally also have ones that fit full length BabyAT and ATX boards, I currently store them upright in euro-boxes, one 600x400x320 box fits like 30+ AT baords, less if ATX, but I've recently started moving them into dedicated cardboard boxes that are 305x220x50 for smaller baby AT boards and 350x250x50 for larger baby AT and non full-width ATX boards so I can store eventual accessories with them easily and have them labeled in plain sight, unfortunately full width ATX boards don't fit in those boxes and larger sizes aren't available for cheap or just too large.
but yes, they do take up a lot of space ^^ I'm using up big part of the basement only for storage... let's not start talking about CRTs
LewisRaz wrote on 2020-05-01, 16:29:This week I purchased an entire PC which turned out to have a broken motherboard.
hey, at least you got a K6-III out of that! hope it works 😀
That 486 board with the symphony chipset (isa only) is a beauty, hope it works.
I ordered an active HDMI to Displayport adapter (yes, they do exist) . It is not retro per se, but the plan is to have it in-line between a VGA to HDMI scaler and a Displayport monitor input . That way I can keep switching inputs on the monitor while using a VGA to HDMI scaler with a VGA card and another DVI card (hooked up to HDMI monitor input)on my main retro rig ( FX5900 and Voodoo 3) .
