First post, by keropi
Hiya!
I just installed my newly arrived voodoo5, but I have a problem: I cannot get windows to anything more than a 1024x768 resolution. This is the max supported 😖 I tried both Amigamerlin 2.9 and Raziel64 Evolution Driver Expert Edition 1.00.09 drivers, both allow the same max resolution....
My monitor is a 19" 1366x768 one , is there a way to switch to this resolution? or anything bigger than 1024x768?
thanks !
edit: I must add that the monitor get's recognised fine, I even installed it's driver...
Reply 1 of 5, by exxe
2D is up to 2048x 1536Pixels, 3D up to 1600x 1200
look for 1366x768 in the 3dfxvs.inf, it should not be there
add it like the other resolutions and reinstall the driver
Reply 2 of 5, by keropi
I cannot get it working... 😒 please have a look at the edited 3dfxvs.inf and my monitor .inf , maybe you see something wrong?
thanks 😊
    ker_infsV5.zip
    10.31 KiB
    445 downloads
Reply 3 of 5, by Svenne
I'll might try this with my Radeon card, or the Winfast if I get DirectX working.
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
Reply 5 of 5, by keropi
powerstrip does NOTHING at all, it DCC's the monitor, finds a max resolution of 1280x720 and does not enable it at all, even if I install it's monitor...
anyway I will search more...
