First post, by vetz
A nice chap is offering one of these to me. If I were to use them in a future 486 setup, which one would you guys recommend?
I don't have so much expertise in the pre-pentium era. From what I've found of info it's a bit conflicting.
Reply 1 of 9, by Anonymous Coward
I'd go with the S3, especially if it can be upgraded to 2MB.
Reply 2 of 9, by vetz
Thanks
It is the version that can be upgraded to 2MB. Dunno how common/uncommon those memory chips are though.
Reply 3 of 9, by Anonymous Coward
They shouldn't be too difficult to find.
Reply 4 of 9, by elfuego
Actually, I'd go with cirrus logic. It was a standard, decent and compatible VGA card back at the time - and it's 2MB. S3 should not be that bad either, but I've had little experience with VLB S3 video cards.
Reply 5 of 9, by badmojo
My experience is that the S3 will be a little faster and perhaps have better vesa support, but the cirrus logic will produce a nicer image.
I'd go with the cirrus logic.
Reply 6 of 9, by vetz
If I find 512kb video ram chips that will physically fit for upgrading the S3 card, will they work? Or are there some other specifications that will need to be met?
Reply 7 of 9, by iulianv
FPM vs. EDO (most likely you need FPM - when you get your hands on the chips just google them for datasheets)
access time might also count, but I'm not sure how much...
Reply 8 of 9, by chrisNova777
this is the video card i have in my Asus VL/I-486SV2GX4
im trying to install the graphics driver found on teh vogons page..
(http://www.vogonsdrivers.com/index.php?catid=47)
i ran the install program.. but it didnt switch my graphics to the new card + i cant find any oemsetup.inf file to be able to change it manually via windows setup.. can anyone offer any guidance on how to install the proper driver for the CLVGA542XVL ?
i exited windows + restarted "win" and it still shows "VGA" in windows setup + not a specific Cirrus Logic driver
im scrolling thru the options in windows setup and it shows GD546X but this is not the card i have.. i have the CLVGA542XL.. is there a difference? or should i just use this option?
when i tried to select the "GD546X 1024x768 with small fonts" option i get error copying files??
im thinking that to fix this i have to choose "other display" and browse to a file called oemsetup.inf.. but the posted vogons driver doesnt have an oemsetup.inf!!
i think the wrong file is linked perhaps on the vogons drivers sites? because looking at the files from the download i see a file "OEM546X.IN_"
should i just ignore that this model number doesnt match my card exactly + use it anyway?
also on my card i see some empty chip sockets.. is this for extra video ram? can i install some chips here to boost the performance of the card? or should i just ignore/dont bother?
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Reply 9 of 9, by chrisNova777
ok i just realized i downloaded the wrong file..
i picked "Cirrus Logic CL GD 5462 und 5464" !!! Ooops! i see the proper driver there now
http://www.vogonsdrivers.com/getfile.php?file … =273&menustate=
thanks so much for making this stuff available guys!! 😀
