Voodoo Graphics SLi?
First post, by sliderider
I was reading the entry for Voodoo 2 in Wikipedia and it says that the original Voodoo Graphics was also capable of SLi but only arcade boards and boards designed for 3D simulators were capable of being used this way. I just wondered if anyone has ever come across a pair of these cards and used them in Sli in a PC?
Reply 1 of 31, by swaaye
Rank Moderator
Moderator
Quantum3D made a few Voodoo1 SLI products.
http://www.thedodgegarage.com/3dfx/q3d_obsidian.htm
I got a 100SB off of eBay about 10 years ago for $30 and messed with it. Performed kind of like a Voodoo2.
Reply 2 of 31, by FeedingDragon
My P2 Win98 system has a Voodoo 2 board that has a SLI connector. What I researched (at that time - Late 90's??) was that you had to have identical boards (not only both Voodoo 1/2/etc..., but same manufacturer and model.) The tech I spoke with then, said that it was extremely touchy getting it to work. Also, in many cases the board pairs in question pretty much had to have specific SLI cables, it seems that different manufacturers used different connector setups. After a while, I just gave up and decided to buy a bigger 3D card.
Feeding Dragon
Reply 3 of 31, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Feeding Dragon, that the v2 can be put into SLI is known and there are enough proofs of it. Sliderider asked about the original Voodoo...
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 31, by cdoublejj
wow it even has an SLI cable, a nice one at that modern sli/cfx cables are kind of bulk with plugs at the end.
Reply 6 of 31, by FeedingDragon
Sorry, I guess I was just tired. I read Voodoo 2 and SLI and just made a connection. Don't know anything about Voodoo 1, never did any work/research with it. Just Voodoo 2 really.
Feeding Dragon
Reply 7 of 31, by elfuego
tincup wrote:
V1 SLI. Now *that's* pretty cool...
I'm gonna be an @$$ and ask the obvious: why? Everything that was meant to run only on V1 will run perfectly, really perfectly, with any V1. Anything that can be run on V2/3/4/5 will run much better on a V2/3/4/5 😀
It could be an item to have just to make a 3dfx collection complete, but I do not see any particular use for it.
Reply 10 of 31, by swaaye
Rank Moderator
Moderator
Some of them have 4MB framebuffer so I imagine 8x6 is a go. Maybe even 1024x768?
Reply 11 of 31, by tincup
swaaye wrote:
Yeah it is really just collectable curiosity.
I disagree! It must have been the bee's knees back in the day - I didn't even know about it. 8mb of 3dfx video ram SLI when the serious games were chugging? are you kidding me? haha! A curiosity now for sure but the real mavens would have *jumped* on it!
Reply 12 of 31, by FeedingDragon
Also SLI didn't just double the RAM, it also set up Dual GPU access. Not quite as fast as getting a processor at twice the speed I'm told, but close. If the 3Dfx chip was the best at the time, then, at that time you would have had almost double the best 😀
On a related subject... I know the V2 deffinately could be SLI but what about 3/4/5?? I never looked into those.
Feeding Dragon
Reply 14 of 31, by subhuman@xgtx
Nope, 4mb just gives you 800x600x16 DB
https://docs.google.com/viewer?a=v&q=cache:4T … wUtm2Rm9BquaFpg
Reply 17 of 31, by elfuego
Please name one "serious game" made explicitly for voodoo 1 (e.g. does not work on V2/3/4/5) that was chugging on vanilla, no-name, made in PRC (China), voodoo 1. 😊
Reply 18 of 31, by tincup
Grand Prix Legends. Released for 3dfx and Rendition. Most people who first played it in 3D would have done so on a Voodoo 1. GPL was the 'driving' force behind most of my CPU/GPU/Ram upgrades at that time.
Edit: Hind too. The 3dfx version didn't really come into it's own until Voodoo 2 SLI, with decent FPS at 1024 res. Basically, "serious" means high-end driving and air combat simulations to me..
Reply 19 of 31, by swaaye
Rank Moderator
Moderator
It's true that a Voodoo1 6MB has advantages with some games because it won't run out of texture memory like the 4MB cards do. But still, the 4MB texture memory of the 6MB cards is not much storage for later games. It's the same amount as a 12MB Voodoo2 has. You really want to go to a Voodoo3 instead of even Voodoo2 SLI. SLI doesn't increase texture storage.
