First post, by northernosprey02
I want to deciding own HP Vectra VL 5/100 Series 4 which formerly used for my mom's office. They had Pentium 100 MHz processor, I want to upgrade them to Pentium MMX 200 but I am hesitant. Should I upgrade VRM first or keep the VRM? The VRM is short block (not active VRM).
Reply 2 of 7, by northernosprey02
And for cooling which is better? Tall passive heatsink or low-profile active heatsink? I use standard metal thermal grease
For sound card, which is better? ESS AudioDrive ES1868F or Sound Blaster ViBRA 16S?
How much I need memory for gaming? 16MB (stock) or upgrade to 32MB?
Is Intel 430FX supporting Pentium MMX? (oops, typo)
Is 3dfx Voodoo1 supported on this machine?
Reply 3 of 7, by luckybob
active > passive
probably the ess, but its not much of a choice
more is always better
usually
as long as you have an open pci slot, yes.
Reply 4 of 7, by northernosprey02
I want to installing CD-ROM there, however to installing CD-ROM I should using drive rail. I don't have drive rail, what can I do?
Should I use DOS 6.22 + Windows 3.1 or Windows 95?
And which is better? S3 Trio 64 or Trio 64V2/DX? I own this video card but I don't have Voodoo1 🙁
Reply 5 of 7, by fillosaurus
I say Win95 OSR 2.1 or 2.5
Trio 64V2/DX is better, of course.
Voodoo box: Celeron 800 MHz, 512 Mb SDRAM, Voodoo 3 3000 AGP, 80 Gig Seagate, Yamaha OPL3 SAx 718+NEC XR 385, SoundBlaster Live!, NEC USB 2.0 PCI card.
WIP: external midi module based on NEC wavetable (Yamaha clone); VLB 486
Reply 6 of 7, by northernosprey02
Err... Something is missing:
According to HP Vectra Familiarization Guide for processor upgrade:
"The 90 MHz, 100 MHz and 133 MHz processors need a passive shortening
block VRM (providing VCC voltage), while the 120 MHz processor needs an
active VRM (providing VRE voltage). The appropriate VRM is provided with
each processor upgrade kit."
I was hesitant when I just reading this. Should I need active VRM or short block VRM?
And where I get the rail kit for installing CD-ROM?
Reply 7 of 7, by luckybob
I'd try it with the regulator installed. then without. Your motherboard may be the case where it will take a 200mhz cpu but will NOT work with mmx. it happens. Before you get too deep in changing jumpers take a picture or make a paper diagram. Its saved my arse more than once in the past when an upgrade refused to work and I forgot what the settings were initially.
if the rails are NOT in the case already, your only hope is finding another hp vectra machine and taking its rails.
