First post, by blakespot
Hey folks,
I have just won this auction on eBay: http://www.ebay.com/itm/370912786816
It's a Cardex ("Challenger," I believe) VLB video card with a Tseng ET4000/W32p and 1MB FPM DRAM onboard. There are four surface-mounted v53c8256hk45 chips which are 256x8 units. There are also four 24-pin DIP sockets for DRAM expansion.
Does anyone have any idea where I can source 24-pin (which seems odd for DRAM), compatible DIPs? I'd like to take the board to 2MB.
Thanks.
bp
:: Visit the Byte Cellar, my vintage computer blog (since 2004).
:: See a panorama of my own Byte Cellar (a.k.a. basement computer room)...
:: twitter: @blakespot
Reply 1 of 9, by blakespot
Apparently I need V53C8256HP45 odd-ball, 24-pin DRAMs, as seen in this shot:
https://picasaweb.google.com/misterzeropage/M … 213357812243922
Info: http://www.datasheetarchive.com/V53C8256HP45-datasheet.html
Might be hard to find... Apparently the RAMDAC is less quality than the one on the Hercules Dynamite Power.
bp
Reply 3 of 9, by Anonymous Coward
I think the RAMDAC on that one is the same as the Hercules.
The cardex in that photo is slightly better than mine.
Reply 4 of 9, by Logistics
You can order them as an End User from Quest components for $3 and change, BUT your order has to be 24.99 or higher so it sort of defeats the purpose unless you want to order other stuff from them.
Reply 5 of 9, by blakespot
Thanks! I ordered 11 ($25.30)... I will list the unused items on eBay, I suppose.
This should get me a 2MB ET4000/W32p similar in performance to the Hercules Dynamite Power I enjoyed back in 1994. It's DOS performance I want, but I recall having no gripes about the board's performance in Win95 and Linux (well, aside from the fact that I had to purchase AcceleratedX, a commercial Xserver to get full res and color depth out of the board).
bp
Reply 6 of 9, by blakespot
Wow. Sierra IC has them for $30 per chip...
bp
Reply 7 of 9, by PeterLI
Interesting. I found out the hard way that VRAM chips are not generic like SIMMs. I bought a S3 PCI card with VRAM chips. I then tried installing them in the sockets on a MOBO of a Digital and a HP but both did not work with them. 😠
Reply 9 of 9, by blakespot
I have the DRAMs in hand, but am doing more basic system setup right now. I upgraded mono cache to 256MB...
https://twitter.com/blakespot/status/422440489162645504
...and am trying to get SCSI disks sorted.
https://twitter.com/blakespot/status/422455555127775232
Last step will be to update the board to 2MB.
At first the board did not work at all. Then I noticed a 3-pin jumper, with pins 2-3 crossed. I assumed that was a 1 or 2MB select and moved the jumper to 1-2 and it worked. Apparently the seller harvested the board of its socketed DRAM before selling. 😀
https://twitter.com/blakespot/status/422125957106110464
bp
