Reply 20 of 31, by swhockey98
blakespot wrote:
I am now using System Commander 7 to good effect in juggling my Win95C partition and my DOS 6.22 partition. And, it's free. […]
VCOM was offering System Commander 7, among other legacy apps, on their "Obsolete Releases" page, here:
http://www.avanquest.com/USA/aq-you/support/o … e_releases.html
Sadly, the dl link is dead. HOWEVER, I decided to give Archive.org a shake an - voila! There's the file!
https://web.archive.org/web/20110809022408/ht … e_releases.html
There was a System Commander 8 and 9 (and maybe 10), after - but 7 supports XP, so...it's just fine for my purposes. FYI.
bp
Good to hear you got it working! Nice find on SC 7, I didn't think Wayback Machine would have cached downloads.
Reply 21 of 31, by pojo
@blakespot
I can't get SC7 to install, I always get this error when starting the installer. Tried in Win95C, 98SE and even 98SE inside VirtualBox.
Any clues?
Reply 22 of 31, by Elia1995
pojo wrote:
@blakespot
Any clues?
Try with System Commander 8.
Mau1wurf1977 wrote:
Cool and thank you for the detailed explanation!
Might be worth checking out for me if I have the time 😀
Knowing you, you might make a video out of it as well 🤣
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 24 of 31, by Elia1995
Honestly, I have no idea, I managed recently (this Summer) to get a dual DOS and Windows boot to work in my Celeron build.
In the end I used XFDISK to format the drive, create the 3 partitions (one so I can "share" files between the two systems, since one hides the other one) and the boot manager as bootable.
I then manually set each one bootable a time, installed the systems and then set the boot manager as bootable, which activates the partition I choose at boot.
Kinda hard to explain textually, but it's actually really simple, I'll eventually make a video of it in the future, if I have the chance to make another dual boot retro machine.
Reply 25 of 31, by Pabloz
its crazy how difficult is to find a copy of old software from the 90s, and 2000s
i was searching for system commander 8 and ended up on a bunch of china websites that required a china cellphone to register
and today i finally found it
VCOM.System.Commander.v8.13-FOSI
wow, who doesnt remember FOSI , their releases were very known
Im not sure if we can share such a link in vogons, the company is dead by now, i wonder if this can be considered as an abandonware software. but it can be found in google.
Reply 26 of 31, by Elia1995
I never heard of "FOSI".
Reply 27 of 31, by bjwil1991
I've booted to MS-DOS and Windows 95 on separate partitions before, and here's what I did:
MSDOS.SYS
;[Paths]
;WinDir=D:\WINDOWS
;WinBootDir=D:\WINDOWS
;HostWinBootDrv=D
[Options]
BootGUI=0
BootMenu=1
CONFIG.SYS
[menu]
menuitem=MS-DOS, Boot into MS-DOS 6.22
menuitem=WINDOWS, Boot into Windows
defaultmenu=MS-DOS,15
[MS-DOS]
DEVICE=C:\HIMEM.SYS /TESTMEM: ON
DEVICE=C:\EMM386.EXE RAM 16384 D=64
DEVICEHIGH=C:\XCDROM.SYS /D:CD-ROM
[WINDOWS]
DEVICE=D:\WINDOWS\HIMEM.SYS /TESTMEM:ON
DEVICE=D:\WINDOWS\EMM386.EXE RAM 16384 D=64
AUTOEXEC.BAT
@echo off
goto %config%
:MS-DOS
lh shsucdx.exe /d:CD-ROM
lh ctmouse.exe /p
smartdrv c+
set path=%paths here%
*sound card drivers*
goto END
:WINDOWS
path=%windows paths%
lh ctmouse /p
win
goto END
:END
Drive C is formatted with the system files (boot files) and Drive D is formatted as-is (no boot files) to prevent conflicts.
Reply 28 of 31, by Elia1995
I've always used XFDISK's boot manager without much problems
Reply 29 of 31, by brostenen
Thumbs up for XFdisk. I have used it as a replacement for Os/2 bootmanager, ever since I discovered it, because of drives became too big for Os/2 boot manager. Works more or less the same. Same feel, same look. Just works.
Things differ though. To me, modifying Win98 boot procedure and configuration is just too complicated. A bootmanager is something that I can grasp and wrap my head around. Though at the same time, people usually use the graphical configuration menu for changing settings on a SB16, were as I just edit the CTPNP.CFG by hand, using EDIT.EXE. Well... I guess it all comes down to what personal taste people have.
Reply 30 of 31, by Elia1995
I'm currently triple booting Dr. DOS 7.03 - OS/2 - Windows 98 in my Celeron rig with XFDISK
Reply 31 of 31, by brostenen
Yeah.... And to be honest, unless you are using a real bootmanager with each operating system on its own partiotion. Then you are not really dual/tripple/multi booting at all. Its like calling Win98 task manager for pre emptive multitasking. It's not.
