First post, by Logistics
- Oldbie
Just like the title says; are there 640 x 480 native LCD's for use with Retro games?
I dare not ask if there are 320 x 240 native LCD's.
In ATi Catalyst Control Center I can set whether my monitor needs to stretch to full-screen, keep the aspect ratio or only use the pixels needed.
If I am not mistaking, I believe there are monitors which have those options built in themselves. You just push buttons and it switches between those modes.
If that's not something you like, try the Sony LMD-1410SC. It seems to be a native 640x480 lcd.
You could also aim for 1280x960 native LCDs 😀
A 640x480 LCD screen would be so old that it would have a high response time. Would smearing hurt gameplay in the games you like?
The Sony LMD-1410SC doesn't appear to have VGA input.
They do make new ones, but they're all either really small or really expensive. Often both. Also, most of the small ones only have composite input, no VGA, since they're designed for use in things like car backup cameras and whatnot.
old LCD also suffering from narrow viewing angle, which probably non issue if you convinced to only watch directly in front of it.
-fffuuu
Depends on when the screen was made. 640x480 LCD has been around for a while in laptops and when laptops went to higher resolution they moved into portable video devices and handheld units.
I have one of these:
http://www.currentdirections.com/hardware/intermec/6622.html
Its 640x480 TFT and looks decent, 486/133, normal laptop HD, 32MB RAM and built in sound (mono speaker). Use it mostly for solitaire before bed and the batteries still last a long time. Made long after you would find a 640x480 LCD in a laptop.
