Reply 12540 of 22840, by Cyrix200+
kaputnik wrote:
Cyrix200+ wrote:
I had been reverse engineering the jumper settings for a MHz display in one of my cases, but I could not get one of the segments to work. I had concluded that the segment must be defective 🙁
Today I desoldered it from the PCB (nice first job for my new desoldering station), and tested it. The segments LED is indeed not working 🙁 Unfortunately it's the middle horizontal one, so I can only make a 1 or a 7 now 🙁
I wonder if I can find a replacement. Finding the data sheet for the display unit was surprisingly easy (and very helpful).
Those 7 segment displays are usually standard off the shelf stuff. Shouldn't be hard or expensive to find a replacement 😀
If you can't find a 2 digit one, I'd guess two 1 digit ones would be fine too. The pin configuration on those displays seems to be pretty standardized.
I have been looking for a replacement last night, the pinout seems standard, and so does the voltage (if I pick the same color). Now finding one (or two) for a decent price (including shipping) is a bit harder. Replacing it with two 1 digit displays seems impossible, it has 2x 9 pins. Will continue the search today.
1982 to 2001
Reply 12541 of 22840, by henryVK
Replaced the little 40mm fan in a shuttle ATX PSU with my first Noctua fan.
Boy, if that wasn't the best 12 Euros I spent on that machine so far! Barely can hear the damn thing now.
Reply 12542 of 22840, by imi
be careful replacing PSU fans with more silent (and often slower) variants, they might not provide enough airflow for adequate cooling and might kill the PSU if it doesn't have good thermal protections, always compare the airflow of the stock fan with the one you replace it with.
It's probably a non-issue if the PSU isn't under constant heavy load, but it is definitely a thing to consider.
Reply 12544 of 22840, by henryVK
Hmm, thanks for the warning. I didn't think it would make a big difference, tbh.
The old one has something like 6.9 cfm over the Noctua's 4.8, but then, there's no great loads on this PSU.
Maybe a good idea to just monitor the temperature for a while. I was actually planning on putting in an additional case fan to help with overall cooling, that might offset things.
Reply 12545 of 22840, by imi
when I got this case the CD drive was jammed into the case, including the drawer mechanism, forgot to take a picture before... only took one after I aligned it...
129.89 KiB
had to pull out the drawer with a flat piece of metal:
126.67 KiB
the open/close latch was jammed, so I opened the drive and almost lost the tiny bearing balls that came falling out ^^... the magnet inside with the metal clips came loose and somehow got jammed inside the plastic housing, after pulling it out and aligning it again it seems to work fine 😀
75.33 KiB
and did a quick cleanup, that's one happy 1992 CD-Rom drive 😀
88.7 KiB
Reply 12546 of 22840, by Turbo ->
That PC case is really nice.
Reply 12547 of 22840, by imi
it is indeed, my first desktop case, I like the "car hood" like opening mechanism ^^ and if that wasn't enough it also came with that odd but awesome mitsumi drive.
Reply 12548 of 22840, by oeuvre
Saw the new Rocko's Modern Life special on Netflix. It was amazing, especially if you grew up watching the show.
Reply 12549 of 22840, by MMaximus
actually I had a similar one and the build quality wasn't great - thin metal and lots of flex. I don't know if yours is built any better?
Love the hood though!
Reply 12550 of 22840, by SpectriaForce
imi wrote:
I'm sure someone would have use for the remains...
If someone is interested in a free Diamond Monster 3D Voodoo with a missing capacitor, then let me know. I still have it.
for ready to use retro game pc's click here
Reply 12551 of 22840, by mothergoose729
I would take it, but you should know, that is five minutes and a capacitor away from being worth 80$-100$ USD 😉
Reply 12552 of 22840, by TheAbandonwareGuy
Depending on what type and which capacitor it is, that may not be a job for a novice with solder.
Reply 12553 of 22840, by jaZz_KCS
Although even a novice with way too gratuitous amounts of solder can easily "blob-botch" one of these if capable of a half-steady hand, which would result in a working albeit ugly result, I do agree.
Reply 12554 of 22840, by Daniël Oosterhuis
If you're serious on that, I'd be on that immediately, sounds like a fun repair project to me!
Reply 12555 of 22840, by SpectriaForce
Send me a PM if you want to collect it or contact me via my website.
Reply 12556 of 22840, by imi
I wouldn't say build quality is great... the metal isn't really thin as such but yes the whole case flexes quite a bit when open because the whole case is just held together by one big U-shaped metal piece (I guess it'd be better if I had it standing on a stable surface), also the whole case is a bit "ouf of shape", but eh, I still like it 😀
Reply 12557 of 22840, by bjwil1991
The CD drive must be a Mitsumi CRMC-LU005S.
Systems from the Compaq Portable 1 to Ryzen 5 2600X
Reply 12558 of 22840, by Tiido
I'm making RAM sticks ~
863.68 KiB
1.36 MiB
Reply 12559 of 22840, by Jed118
If you're in the GTA, I know where to get these for pennies. Old school ones too.
What's for sale? my eBay!
