Reply 12660 of 23624, by PcBytes
- Oldbie
wrote:Green board is a Gigabyte GA-8SIML, and there is a stock GB BIOS.
https://www.gigabyte.com/Motherboard/GA-8SIML-rev-1x#ovAlmost, its SIS651 mobo, OEM for PB. SIML-NF11Ai
8SIML bios should work.
If you're skeptical, just take the PLCC bios chip from a scrap board, flash it with the stock 8SIML using flashrom and test it on the 8SIMLNF. You have a removable BIOS socket, which should take care of not being able to recover in case the new flashed BIOS chip doesn't play with the board.
