Reply 17000 of 27413, by Jed118
- Oldbie
I got a bunch of stuff locally:
There's a rather nice 386 SX-40 which looks like it was upgraded as there's an 8 bit ATI VGA/EGA card in there, a 44 MB MFM drive, other hardware that seems to fit better in an XT or early AT, and surprisingly the battery holds a date and hasn't leaked (will be removing it regardless). Floppies both work too, high density units.
Doesn't work - spins up lights flash, then spins down. I put in the CHS parameters in BIOS, the drive spins down and then gives a C drive error. I'll play with it some more later.
So the VLB I/O cards don't detect IDE drives (at least on the supplied motherboards) otherwise fine. The 8 bit floppy controller gives a 1701 error, the 16 bit I/O cards seem to work fine as well as the two ISA video cards. The Mach32 initially showed garbage, but I reseated it and it worked. It also displayed properly with the second motherboard. Motherboards are 486 VLB, one with a 33MHz DX chip, the other with an OverDrive 486 DX 33 (shows as a 66Mhz in tests - will be removing that one for my personal collection and replacing a standard DX2/66, as I have a few). They both need batteries, one had a barrel removed (extremely minimal leaking, I think I might be able to solder to the battery points) and the other one is an integrated RTC. Which is soldered on. And it's the type that won't let you get past POST on a dead battery. Fun!
The other box is a working P166 MMx - that'll be eBayed to cover the costs of all the other stuff.
I also got a chance to work with my IBM Blue Lightning - it's been sitting in my basement since I moved. I'll start a separate thread on that as I have specific questions.
All in all not a bad haul 😉
What's for sale? my eBay!
