Reply 19280 of 22099, by bjwil1991
Working on an NES that doesn't load games (well, SMB + Duck Hunt) and it boots the game with the cartridge toaster at the eject mode and not the insert horizontal mode (pressed down) after adjusting the bottom pins.
1.04 MiB
And dummy me didn't plug the controller port wiring in the correct spots (port 1 is now port 2, port 2 is now port 1), so it'll get sorted out and the edge connector will get the boiling treatment.
The one at the bottom works without issues (had to spray 99.9% Isopropyl Alcohol on the edge connector and it's good and grippy for how old the console is, which might've been a spare in case the other one didn't work after many years).
1.05 MiB
Here's the working one in its working glory.
Also greased the trigger on the Zapper since it was making a loud noise when I was playing Duck Hunt.
Reply 19281 of 22099, by brostenen
pentiumspeed wrote on 2021-06-24, 23:55:
One day, my closet shelf about 9 feet long suddenly collapsed, I was away at work, prompted complete clean out of my large colle […]
One day, my closet shelf about 9 feet long suddenly collapsed, I was away at work, prompted complete clean out of my large collection of parts so our apartment staff can install new shelf, this time stronger.
The stuff is fine since shelf held up at one end, few boxes tumbled. The design of shelf is metal railing with a ledge for the hangers to hook on formed structural strength didn't buckle. Reason for this poorly made, 3 pieces of full length wood are nailed into drywall on 3 sides with this metal railing at front and glued which thin plywood loosely sits on (broken on impact along with 2 wood pieces ripped from the walls. This issue is one wall is a projecting from main wall vibrates easily no matter how gentle with impacts was the cause.
Reason I saying that, was shocked to find Asus 386DX with cache motherboard during clean out, that I was totally forgot about.
Cheers,
Reason why I use standing metal shelf's.... 40cm deep and enameled metal. (Basically high quality garage shelf's)
Reply 19282 of 22099, by creepingnet
Site's back up. Just needed to e-mail Neocities. Worked on the site some more, fleshing out the NEC Versa Section currently - basically a series of comprehensive guides to the laptops beyond what's on google sites. Not uploaded yet. I'm thinking I'll host the file downloads on my Geocities.WS site, maybe with a backup repository of the files - since I have unlimited bandwidth, storage, and it means people with vintage computers and no TLS/HTTPS support can get to the downloads.
Tested the site on my LG Stylo 6 and the Versa M/75 this morning. Looks nice and is quite usable in both - although a little more spartan. Will probably try out in RetroZilla once the in-laws are done visiting.
~The Creeping Network~
Reply 19283 of 22099, by BeastOfSoda
I finally, FINALLY managed to get Wing Commander 3 working on my Piii build. Everything that could have gone wrong, went wrong, from dodgy audio drivers to gremlins crashing the game for using an USB mouse, along with parts taking months to arrive or not being up to the task, topping off with an SB16 dying on me, but the satisfaction of having it run reliably is simple bliss.
Reply 19284 of 22099, by LewisRaz
Got my first recording up from the new soundcards that I picked up.
https://www.youtube.com/watch?v=z2or2Qdq0dw&a … nel=LJRRetroPCs
Of course the first upload is DOOM! 😀
Using the ES690F Wavetable Synth on the card.
My retro pc youtube channel
Reply 19285 of 22099, by bjwil1991
Replaced the 72 pin edge connector and cleaned most of the NES off and it works.
Also made sure I plugged the controller port wiring in the correct spots this time.
766.86 KiB
So I now have 2 working consoles and all that's left is to get an NES power brick, a few more games, 2 more controllers, and another Zapper so I can have 2 consoles on 2 different TV sets (CRTs).
Reply 19286 of 22099, by BitWrangler
Yay! Can I send you a NES, a GameCube, and 4 Xbox 360s to get working for me, maybe a Wii or two with a software issue? 🤣
Just kidding, but the console "round tuit" pile never seems to get any smaller. May not even be much wrong with some of them. I think I'd have plucked out an original xbox or dreamcast to play with if either of those were in there though.
Reply 19287 of 22099, by Aebtdom
I have installed my freshly arrived geforce 4 ti4200 128mb from leadtech winfast series.
It had some glitches before installing but seen it only once. Only thing I am facing now is that I can't seem to get my voodoo 2 SLI up and running again, but maybe I have to take skme more time to investigate the driver kind of issue.
Builds:
Xp2400+ gf3 ti200 + vd2 SLI 12MB + 768MB + SB live @ WinXP & 98 Dualboot.
MMX233 + S3trio 3D/X2 8MB + 3Dfx Voodoo 1 + AWE64 + 64MB SDR @ msdos / win98.
Reply 19288 of 22099, by Caluser2000
canthearu wrote on 2021-06-21, 09:18:
Just for giggles, I pulled out an old SFF Compaq with 1gig ram, 2.4ghz P4 and ATI Radeon 9550. Installing the operating system ( […]
Caluser2000 wrote on 2021-06-17, 23:15:
Got the Shuttle Xpc sorted. About a minute and a half to boot to the desk which is Cinnamon on Linux Mint Debian Edition. If you look at the system info shot below you'll see how much resources this little beauty has. So if someone says Xwindows is slow or there is no modern operating system for older 32-bit x86 hardware that is regularly updated tell them to go pound sand 😉
I'll create a dedicated thread some time to explain the small issue I had a some time.
Peace out.
Just for giggles, I pulled out an old SFF Compaq with 1gig ram, 2.4ghz P4 and ATI Radeon 9550. Installing the operating system (LMDE) went ok, and I'll admit, it wasn't really slow when it first booted.
But loading firefox and going to a website caused it to slow to a bloody crawl. Youtube is completely out of the question.
I also tried playing a video on it, old SD DIVx file. It worked ok at standard size, but started chugging once expanded to full screen. I'm going to try VLC, see if it will perform better than the default media player.
The P4 is obviously not the best PC to be running a modern linux distribution. If I were a patient person, then I suppose I could use it to do some basic office style work. But I'm far too spoiled by actual fast hardware and the capabilities and snappy performance to even put myself through "trying to do work on really old PCs" again. I tolerated it while I was young because I couldn't afford any better, but always pushed for more performance.
P4s were in production for 10 years- https://www.cpu-world.com/CPUs/Pentium_4/index.html And there were numerous variants- https://www.cpu-world.com/info/Intel/Intel_Pentium_4.html
I can assure you all of them play YouTube videos with out any issues at at all. All they are the one core 2 thread versions. I use this one , 3.2Ghz ,to view real time footage from our security cameras. And edit the local law enforcement, aka Police, are interested.
Thank you for confirming Linux loads fast and is easy to install
LMDE is not the operating system. It's the pretty bit which sits on top of Xwindows, which sits on top of the drivers and kernal. Gnome, KDE, XFCE4, MATE, Cinnamon are also pretty bits. I generally ignor Gnome and KDE because of their extra overhead with respect to system resources. Linux can be installed as a cli only operating system . This is great for servers. It doesn't need the pretty bits at all to function, unlike MickySolft Windows 10
I tested two more distros:
The first was BunsenLabs Lithium which is quite a small initial install that can be built on using repositories, including Debian repositories. - https://www.bunsenlabs.org/
The second was 32-bit Devuan BeoWolf 3.1 . This is a Debian derivative that uses sysinit instead of systemd- https://www.devuan.org/
Both of the above distros ,using Firefox-esr ,ran YouTube videos just fine.Like this one - https://www.youtube.com/watch?v=SzIS_q4yS88 I'm trying to recover data from my brothers one...
And all of these distros are current and updated on a regular basis and function as they should on all of my P4 HT systems, 2.8GHz, 3GHz and 3.2GHz.
Take care now 😀
Edit: Shivers I forgot to mention the my 1.6Ghz Atom based EeePC does as well. I'm quite forgetful these days, being 60 plus en all...
Reply 19289 of 22099, by Mister Xiado
Bought a 15" 4:3 VGA LCD Hewlett Packard monitor with inbuilt speakers, to match the 17" iteration I already had. While I have a like-new Packard Bell CRT, I don't want to use it until I have a project that would be better served by it. Like taking a photo of the system it came with playing Quake or something, but at the moment, it's got Windows 3 on it, with a PB user environment. I do need to drag it out some time soon to perform a DALLAS transplant, as I finally bit the bullet and bought a Hakko FR-301 to make such tedious jobs much less tiresome.
If I manage to slap together enough older systems, I could make a sub-network on my LAN suitable for Warcraft 2 multiplayer, but then, I'm not 15 anymore, so inviting people to come over and play video games is about as doable as getting AB- unicorn blood.
Reply 19290 of 22099, by pan069
pan069 wrote on 2021-06-20, 06:08:
pan069 wrote on 2021-06-14, 06:36:
Messing around with my Windows 98 rig today, playing some games etc. Suddenly my my CDROM drive stops opening, stuck. Needle/pin opening doesn't work, like there is no mechanism behind it to push open the drive. Super frustrating, I have had this happening to so many drives before, not sure what causes this. I opened the drive (an AOpen 40x model CD-940E/AKU), an absolute bitch to open up specially since I couldn't open the drive tray before disassembling so I couldn't remove the front panel. Then after having it opened, it gives me access to the bottom side of the drive. After removing the PCB I was able to manually trigger the drive to open by shifting a latch from left to right which drops the inner drive assembly (the one with the lens) and ejects the tray. However, I wasn't able to figure out how to further disassemble the drive so I left it at that. After putting the drive back together and reinstalling it, no juice. Same problem.
When is there going to be some smart person putting together the GoTek of CDROM's? All this mechanical stuff seems to failing left and right... 🙁
Managed to fix that CDROM drive today, yay! Replaced the drive belt, now it opens again like a champ!
Managed to fix two more drives that were equally stuck. How about being on a roll? 😀
Reply 19291 of 22099, by Caluser2000
Went for a 400km motorcycle ride in the rain...😉
Reply 19292 of 22099, by liqmat
Caluser2000 wrote on 2021-06-26, 14:13:
Sounds invigorating actually. Especially if there is lightning. Nothing worse than the Colorado hail storm I hit years ago. It literally was all ice and no rain. Complete downpour. Surreal.
I'm joking about the lighning of course. Did you see this? Crazy! >> https://people.com/human-interest/lightning-s … uck-windshield/
(っ•́。•́)♪♬
Reply 19293 of 22099, by Caluser2000
liqmat wrote on 2021-06-26, 14:31:
Lol.
I always return home in a better mood than when I left. It's my "happy place" if you will. Any day on a motorcycle is a good day ..😀
Reply 19294 of 22099, by LewisRaz
Had to reupload but got my recording of the transport tycoon deluxe soundtrack up on youtube with the ES690F Wavetable Synth.
https://www.youtube.com/watch?v=O8nZ0RBn4Y0&a … nel=LJRRetroPCs
Reply 19295 of 22099, by MotoPete
123.89 KiB
That moment when you're poking through old boxes at your oldies place, only to find a copy of dozens of games you loved as a kid!
I had no idea they had it!
Hmmm... so this is what winning the lottery feels like!
Reply 19296 of 22099, by MotoPete
Love that feeling when something that's got you stumped just comes together! Happy days! Enjoy!
Reply 19297 of 22099, by Joakim
MotoPete wrote on 2021-06-27, 06:43:
20210627_163802.jpg […]
Sweet! I long to visit my oldies for this reason ..usually it's with kids though and I don't have time to dumpster dive.. they are a bit messy, which means that they might have some treasure like old forgotten computers.. A dream is to find the old amstraf or what ever it was we had to play kings quest and winter games on when I was 6...
Reply 19298 of 22099, by Thermalwrong
LewisRaz wrote on 2021-06-27, 06:27:
Wow, thanks for recording all those different soundtracks with that card 😀
Personally I like the OPL3 version of Transport Tycoon soundtrack since it sounds pretty excellent for just FM. I didn't realise the MIDI version sounds great too though.
Is it because of youtube or are there compression artefacts on some of the sounds? At 9:02 it sounds a bit squashed.
Reply 19299 of 22099, by liqmat
Out of anything that I find at garage sales nothing excites me more than a big box of floppies to explore. Don't know why, just a thing.
(っ•́。•́)♪♬
