Reply 19860 of 20445, by Merovign
I took apart, cleaned thoroughly, and then reassembled an off-brand wireless keyboard before I realized the wireless dongle was missing. So that was fun. Part of me wants to try to swap out the control board for a vintage/retro project, I guess I'll make that #933 on the project list.
I have lined up a huge box of parts to test and planned on doing it today, but I kind of never got up and went today.
I did pick up what I thought was going to be a VisionTek GF3 and turned out to be a VisionTek Radeon 9600 yesterday, so that's something! Still haven't tested it yet, it's in the test box, which is overflowing.
*Too* *many* *things*!
Reply 19861 of 20445, by BitWrangler
Some of them (Edit: random wireless keyboards) have a USB compliant HID interface that you can internally solder up a USB cable for. It's a bit of a PITA to dig out the data sheets and brain it all out though.
Reply 19862 of 20445, by Merovign
BitWrangler wrote on 2021-09-06, 02:54:
Yeah the other option I had in mind was puzzling out the ribbon connector on the membrane and creating a bridge or something for an older keyboard PCB - someone used a arduino-like chip to make a wireless keyboard wired, but it was a ton of work. Mind you, they put their plans on the internet, so they did most of the homework.
https://chadaustin.me/2021/02/wired-sculpt/
Proooobably more than I want to do as it's an 80-key and I prefer full keyboards for most purposes.
Also, I was digging into another slimline with a ton of errors (everything was unplugged or bent by an angry gorilla), when I found that one of the PCIE 1x slots was shrouded by the PSU. So, I looked and there was something next to it:
164.14 KiB
I mean, obviously, the mobo wasn't designed for this case, but it's every so slightly entertaining to see the designer's "what the heck it'll fit" moment.
Edit: Yes, I'm bored. I get bored when I'm tired because if I could do things I wouldn't be bored. 😀
Reply 19863 of 20445, by Jed118
I retrobrited a Magitronic 14 inch CRT. The front part came out well, the sides of the bezel fair, and the rear cover not so good (lots of marbling) but from head on, I'm quite happy with the results. Funny thing is, the INSIDE of the monitor case was yellowed too!
What's for sale? [https://www.ebay.ca/sch/the_kombinator/m.html … =1&_ipg=&_from=] my eBay! [/url]
Reply 19864 of 20445, by appiah4
Repaired a 286 motherboard..
499.67 KiB
658.85 KiB
..and got it fully working. Yay me!
523.09 KiB
86.07 KiB
271.73 KiB
Reply 19865 of 20445, by Old_Jelly
So the fans on the Voodoo 5 5500 are going to drive me insane and that is a fact. So to remedy the situation I ordered some Noiseblocker BlackSilentPro fans 40mm. Now this would be a straightforward DIY but it seems people don't know how to count these days so I got only 7 rubber spacers instead of 8.
This is very easy to fix don't get me wrong but the fans were pricey and I want it to look good. I contacted Blacknoise and are now waiting for a response. Here are some pictures of the DIY
253.4 KiB
258.24 KiB
252.48 KiB
Reply 19866 of 20445, by Caluser2000
Connected the broken fan pwr leads to the Hypertech Max Pro 200(WinChip 200) cpu. Added new heat sink compound after cleaning the old stuff off and clamped it all together. I'm going to apply a small dab of Gorilla Grip adhesive on each of the fan/cpu corners to hold them together when it dries and I will remove the small plastic clamp.
    323.76 KiB
Reply 19867 of 20445, by TehGuy
I've been swapping my P4 and dos machines out with a slot 1 + slotket for the past 2-3 hours. My floppy cable was keyed the wrong way for the board so I got to run that upside down.
Still hate molex connectors to this day; dunno who designed something where the pins can shift around as you try to plug them together. Just praying the fan headers on the GA-6BXC actually spin the case fans up... Well, back to putting this stuff together and cleaning up so I can go to flippin sleep
Also my room's not always this messy I swear
Win98+DOS: VIA C3 Ezra-T 1.0AGHz, 128MB RAM, AWE64 + Orpheus, GeForce 2 MX400 AGP, 32GB CF card
PowerMac G4 QS + GeForce4 Ti4200 (with ADC)
XP/7: Core 2 Extreme QX9770, 8GB RAM, Radeon HD 7850, X-Fi Titanium
Reply 19868 of 20445, by Shagittarius
Caluser2000 wrote on 2021-09-08, 00:53:
https://www.youtube.com/watch?v=zHmw0u2G9kw - For your Bundaberg
Reply 19869 of 20445, by Disruptor
Finally, got my Token-Ring running.
It's running with:
Olicom PCI Token-Ring card
IBM PCI Token-Ring card
Synoptics LattisRing 2702B-C hub
Ring speed 16 MBit/s
ICMP maximum unfragmented payload in Windows 2000: 4028 bytes
Still struggling with a 3Com TokenLink III 16/4 3C619
Reply 19871 of 20445, by Caluser2000
Installing Lubuntu 10.10 on my AMDk6-2 400 rig with 256megs of ram. Why? Because I bloody well can.....😉
Reply 19872 of 20445, by GuillermoXT
Got my 486DLC and 4c87dlc installed 🙂👍
https://vm.tiktok.com/ZMR5W5K1R/
My Retrosystems:
K6-2 400 running Win98SE
P1-133 with Win3.11
Tandon 286-8MHZ Running DOS 5.0 on XT-IDE Card
Reply 19873 of 20445, by Nexxen
I removed and tested some caps.
A few tested better than ever even after 25 years. Others were KO I wonder how they hadn't burst yet...
One in particular had a strange reading, 7400µF 25V instead of 330µF. 20%vloss and 0.8 ohms.
That one was looking terrible and was bulging on both ends.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 19874 of 20445, by xcomcmdr
Caluser2000 wrote on 2021-09-08, 18:41:
Ubuntu, for the people who can't figure out Debian. 😉
Reply 19875 of 20445, by Caluser2000
xcomcmdr wrote on 2021-09-09, 07:10:
Don't you mean Arch?
I understand you had issues with it despite the excellent documentation it has....😉
Reply 19876 of 20445, by appiah4
Ubuntu and Debian are not that far apart really.
Reply 19878 of 20445, by Caluser2000
xcomcmdr wrote on 2021-09-09, 08:12:
That's why I use Xubuntu, to make Debian fanboys cry in the night.
Because you can't handle Arch you don't you mean?
How do you know someone is an Arch user? They will tell you multiple times in one posting...😉.
Reply 19879 of 20445, by xcomcmdr
Caluser2000 wrote on 2021-09-09, 09:49:
I use Arch, btw.
