First post, by computergeek92
So it appears Windows XP does not support formatting 5.25 disks which is strange because the 1.2mb max size is not much smaller than the 1.44mb max of 3.5 disks. Does Windows 95/98 support format/write/read 5.25 disks since their design clings to ms-dos? Or should I just use a PC with Dos 6.22 and Windows 3.11 to use 5.25 floppies?
I've also tried the freeware Omniflop, but when I used it to format dos 1.2mb and then selected my img file it would stop at 10% and stated something like "floppy write failed. operation was aborted." What could be causing this error? The 10% fail error was with an img file I made by creating a file, archive to zip, then renaming the extension to img. When I tried writing an img file I downloaded online, the write did not even start and I was presented with the same error message.
Any help is very appreciated, Thanks.
Dedicated Windows 95 Aficionado for good reasons:
http://toastytech.com/evil/setup.html
Reply 1 of 5, by smeezekitty
Windows 98 definitely can but I thought XP does too although I never tried it personally (only machines with a 5 inch drive are 486s)
Reply 2 of 5, by konc
Assuming that there is BIOS support, all OS's until windows 7 that I'm aware of can use 5.25 HD drives and format disks on them. The trick is that since XP, for everything else other than 1.44 disks you need to manually specify the parameters in the command line, like format x: /T:80 /N:15 if I remember this correctly.
Reply 3 of 5, by oerk
I think konc is correct. I had one working in XP. Never tried it with newer versions of Windows, though.
Reply 5 of 5, by 2fort5r
IIRC, 'three-mode floppy drive' is a Japanese design that treated the 3.5" disk as if it was a 5.25", producing disks that were logically identical to 1.2MB 5.25" but using the smaller more portable disk.
Account retired. Now posting as Errius.
