First post, by 386SX
Hi,
I have this GMB-486SPS PCI SIS 85C496 based motherboard. I've replaced the battery and cleaned the traces, some were going to expose but I've tested and there's connection. I've set it up for 486DX Intel cpus but I've no cache of 32pin (only 4 without a tag) so I can't use it.
The point is that at boot even with an ISA vga monitor stay black. With the pci test card it show 00... some times 0... sometime it has gone further but nothing to screen.
Is the cache essential to boot or there's some problem?
Reply 3 of 14, by darksheer
Wait for confirmation but I think that only 486 motherboards with fake cache chips will allow you to boot without it installed because their BIOS have been customized to counter that, else it should not boot if you don't have some or you're not respecting the specified configuration.
Reply 5 of 14, by darksheer
tyuper wrote:
Is it behaving the same with unplugged keyboard?
Oh I make a great mistake by "boot" I was refering it as "post" in my previous answer.
A 486 motherboard without keyboard should post but won't allow you to boot if you don't have set the settings that allow it before (Like alt on : no errors) in the BIOS.
Reply 6 of 14, by tyuper
My question was addressed to OP. 😀 Because I have the same board (DTK PKM-0033S) and it was "dead" with plugged keyboard until I replaced broken fuse.
Photo of the board with marked position of fuse.
http://i62.tinypic.com/104k9k2.jpg
Reply 7 of 14, by darksheer
Yeah the KB broken fuse can indeed be an issue to explore as well as broken traces and bad contacts for the BIOS/cache chips but if he does not have the TAG chip installed yet, that won't change anything.
Reply 8 of 14, by 386SX
Here I am. The motherboard don't post, nothing at screen. The keyboard lights seems to power up instantanely as usual but no effects pressing keys or whatever.
I can't see the linked photo, can you attach it here cause my browser is too old.
Reply 9 of 14, by 386SX
Or tell me the name of the component/fuse. 😀
Reply 12 of 14, by 386SX
But as tag can I use a single cache chip and don't put the others?
Reply 14 of 14, by 386SX
Well, it seems there're different traces broken not visibly but the multimeter can't. But they are beyond my soldering skills cause some goes to smd resistors and are really rreally thin wires... 🙁
I think I'll suspend this repair...
