Reply 20 of 31, by appiah4
dr.zeissler wrote on 2020-01-17, 07:35:
I put a S2-Midi Module on my SC1630 Soundcard and configured that MPU uses the SB-IRQ's. This works for "overkill" and sounds p […]
This works for "overkill" and sounds pretty nice on my 286/8! I can't see a slowdown compared
to no music at all.
I will take that thing out and use a midi-breakout-cable in order to use my SC55 and MT32.
Though I have no slot free and I am not able to use softmpu (386+ ems), but I will have a look
what MT32/SC55 games will work without intelligent mode.
We will see.
Greetings
Doc
Are there even any games that run comfortably on a 286 and use General MIDI?
Reply 21 of 31, by dr.zeissler
OVERKILL 😀
Retro-Gamer 😀PowerMac 6100-66/Houdini 486/66 - G4 Cube 450/Rage128pro OS9.0.1 - Macintosh LC/Apple IIe Card OS6.0.8 - Acorn A4000 Archimedes - Unisys CWD 486/66 + Aztech Washington
Reply 22 of 31, by appiah4
dr.zeissler wrote on 2020-01-17, 08:41:
OVERKILL 😀
I guess with something like the Dreamblaster S2 or X2 using the Dream soundbank you can set it to MT-32 mode and run MT-32 games that use the standard sample set (like Monkey Island, Larry 2, Space Quest 3 - I can't think of any others off the top of my mind).
Reply 23 of 31, by dr.zeissler
Is there a list, what games do make use of the standard set and do not require intelligent mode.
Reply 24 of 31, by appiah4
dr.zeissler wrote on 2020-01-17, 09:27:
I believe there is another thread in the forum currently with someone else asking this question. If there is a list, I do not know..
Reply 25 of 31, by CrossBow777
I used my Turtle Beach Maui on my 286-16mhz in the early 90s without any noticed slowdowns. It sounded good for the games that could support it but most didn't back then. However I can say that Dune II actually ran very well on that 286 as did both Wing Commander 1 and 2. Although with WC2 I had to literally dump everything off the HDD in order to play it as I only had a small 20Mb MFM HDD in that 286.
Later when I got my 486 I had an SB-16 (1st gen) paired with my SCB-55 and that worked great for a majority of the games! I'd imagine that it still would have been usable for Sierra games that supported both MT-32 and Gen Midi by then in the early 90s on my older 286 as well.
Midi Modules: MT-32 (OLD), MT-200, MT-90, SD-20
Reply 26 of 31, by Anonymous Coward
If you have a 12MHz AT you're doing great, especially if it's 0WS.
I think a 12MHz 286 with EGA hardware and an MT-32 would be pretty badass.
Reply 27 of 31, by maxtherabbit
appiah4 wrote on 2020-01-17, 11:28:
List of Real Mode games that utilize MT-32/GM (for AWE emulation)
Reply 28 of 31, by dr.zeissler
I only have 286/8 no upgrade possible. first testing-sessions done...mixed experiences. (Dreamblaster S2 internal, SC55/MT-32 external)
Now I am checking if I can set the Dreamblaster S2 to mt32 compatible mode. Autoexec.bat "SET MIDI=SYNTH:2 MAP:E MODE:2"
Reply 29 of 31, by appiah4
dr.zeissler wrote on 2020-01-17, 17:04:
That is not how it is done.
Reply 30 of 31, by dr.zeissler
How is it done?
Reply 31 of 31, by dr.zeissler
I think there is no Mt-32 compatible mode for the S2.
The S2P can be set via softmpu:
USING SOFTMPU: DREAMBLASTER S2P MODE
You can download the special softmpu DOS TSR version compiled executable and sources from
https://github.com/pdewacht/softmpu
Run SoftMPU specifying the parallel interface to be used and the base port address of the MPU-401 interface, e.g.
SOFTMPU.EXE /MPU:330 /OUTPUT:LPT1
To enable MT-32 compatibility, add the /MT32 switch to the command line, e.g.
SOFTMPU.EXE /MPU:330 /OUTPUT:LPT1 /MT32
A Sound Blaster base port address and IRQ can optionally be specified if MPU-401 interrupts are required.
We are also working on a patching utility, and had success patching doom for S2P compatibility, so far.
But no softmpu on 286/8 🙁
