First post, by Tomelloso
Hello friends of retro pc, here is my question'm readying an IBM 486 DX2 66MHz HDD 1024 megawatts - vga t4000w32 - Sound Blaster 16 or AWE 32 I'll see where I put the question comes with RAM, I tell the pc will be intended as original as possible of that time and that model with MS-DOS 6.22 in Spanish - Spanish Windows 3.11 - Spanish office 4.5 - 4.0 corel some Spanish - in short programs as faithful to that cycle of 486 DX2 66MHz and of course I'll put a collection of 30, 40 games of that time DX2 66MHz mythical .............
1 - What would be the amount of ram edo this machine deserves so that it does not fall short or excessive 8MB, 16MB, 32MB ?????
2 - T4000w32 mega card is 1 and brings 2-socket extension, memory sockets can desoldering other graphics and enlarge 2 megabytes but not to memories you going to sit well .... not going to be the joke, that as this extension is ???????
3 - What would be the top range game that pondríais requiements on this computer that is fluid and playable and enjoyable ????
Here is the link to the machine in question is beautiful this machine:
http://mastodonpc.tripod.com/personal/6381-my0.html
Thank in advance your comments and suggestions you can think to put this machine to point THANKS
Ahh by the way I tell you how I got my name an acquaintance and told me .... I heard somewhere that will throw those old computer that you like them to come by or throw the container and went flying .... 🤣 I was complete with ibm monitor, keyboard m, manuals, drivers, fuck up the invoice with the stamp of the store, which fools go throw such a beautiful machine ...
Reply 1 of 20, by leileilol
1. just 8-16MB. Stuff demanding 16-32 also would demand a higher-end 486 (DX4 100mhz+) or Pentium anyway. Going over 16mb is excess, unless you're going to run Windows NT
3. Not Quake, that's for sure 🤣. Though Command & Conquer (NOT GOLD OR RED ALERT), Diablo and Duke Nukem 3D could be played to the end with those specs. there ain't going to be a top-end game that'll be fluid.
Reply 2 of 20, by alexanrs
16MB should be more than fine. It is way above what was common by the time 486DX2-66 were the top PC processor. It should not hurt to get more (unless you go over what the motherboard can cache), you can always create a huge RAMDisk or rum SmartDrv with an obnoxiously big cache.
Look for games up to 1993. That is the year the original Pentium was released. Given that the original 60/66MHz Pentium commanded a premium, even games from 1993 should run pretty well in a DX2. Also, although DX4 and Socket 5 Pentiums came mid-to-late 1994, not everyone upgraded straight away. So even stuff from 1994 might run pretty well on that CPU.
Reply 3 of 20, by Tomelloso
I do not think installing Windows NT will be a machine only intended to MS DOS 6.22 and Windows 3.11 and its games that really work well in speed of 486 DX2 66MHz I want a pure machine at this speed for other operating systems have proposed other retro pc pentium 60-120 - 166 and up to 200 mmx.
So if I see important in this machine 486 DX2 66 is to expand integrated motherboard is a T4000w32 vga I have 2 sockets free expansion and different type s3 vga, sis, logic cirrus the chart, desoldering his memoirs but not to memories will the right to expand my vga 2 mb I do not like to break anything it gives me a little afraid to break the motherboard ????
As it should do ??????
Reply 4 of 20, by brostenen
16 mb in a DX2 is really a nice choice, if it's a MS-Dos rig with Win-3.11.
Back in the day's, we had 4 to 8 megabyte in those kind of computers.
Reply 5 of 20, by Skyscraper
For Windows 3.1/3.11 16 MB as others have suggested is enough and 32MB is enough for running Windows 95 without the IE4 Windows Desktop Update.
Reply 6 of 20, by matze79
i got 64Mb in my DX4, runs DOS, Windows 95 and Debian Etch.
32Mb wasnt enough for Win95 and Linux. (Cacheable Area is 64Mb so i'm fine.)
16Mb is enough for MS-Dos.
Most Games don't requiere more RAM.
And the Games that need more, would also need a Pentium to run flawless.
(Hope spelling is correct.)
Reply 7 of 20, by Robin4
I recommend 8 MB as minimal when in dos and or windows 3.1 / windows 3.11 ( when bought new mostly it was equiped with 8 MB of ram. Only 486 SX version came equiped with 4 MB only, because ram was very expensive back in the day.
But as standard i would recommend at least 16MB.. (in the same situation as above)
If you want to use memory manager i would recommend to go 20MB as minium.
When if you want to run windows 95 on the system i would at leas recommend to go for 32MB as minimal.
Reply 8 of 20, by kixs
1. depends entirely on what you want to run on it. But there's no reason not to upgrade to 32MB or more
2. you didn't mentioned what BUS this 486 has. Probably VLB or PCI. Tseng ET4000/w32i (or p) get a great speed increase with 2MB of memory - but in Windows only!
3. I played Warcarft II a lot with 486DX2-80
Reply 9 of 20, by matze79
To Point 1:
Just Upgrade to more RAM if your Cache can Cache your whole Memory.
Many Operating Systems will slow down, if your Cache can't cover all RAM avaible.
Or Upgrade your Cache.
WT:
32kb 8MB
64kb 16MB
128kB 32MB
256kb 64MB
512kb 128MB
1024kB 256MB
For WB just divide RAM :2.
32Kb = 4Mb cacheable
256Kb = 32Mb cacheable..
Reply 10 of 20, by DonutKing
Back in the day I had 4MB in my 486, later upgraded to 8MB.
Nowadays, for a DOS games rig I like to have 12-16MB as you can run SMARTDRV which speeds up disk access a bit and also configure 4MB as EMS for any games that require it. This lets you run the vast majority of DOS games without having to use a boot disk or set up a boot menu with different system configs.
There is still the odd game out there that will refuse to work in this config (like Ultima 7 or Turrican 2) so you can't get away from it completely.
Reply 11 of 20, by firage
8MB was a more likely pairing, but 16MB is perfect. I wouldn't consider more than that in any DOS/Win 3.1 machine or even Win95 until about a P100, because the benefits are marginal and there are DOS games that actually present issues with more memory.
My big-red-switch 486
Reply 12 of 20, by ynari
Really, more than 8MB was only required if you ran OS/2, NT or Unix. I'm not sure there's many DOS games that need more than 4MB, but there's definitely a number that need over 2MB.
Reply 13 of 20, by tayyare
Star Wars Dark Forces and Bioforge was the first 8MB games I've ever played (1994 or 1995) and I remember that, me and my mate put together a single 8MB 486 from our own 4MB machines to play them.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 15 of 20, by xjas
ROTT ostensibly ran with 4MB IIRC but 'strongly recommended' 8MB. It's a little earlier than Descent or Dark Forces but not much. I seem to remember Doom being acceptable on 4.
Reply 16 of 20, by tayyare
Doom was acceptable (to me) on a 4MB 386DX40. 😈
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 17 of 20, by jesolo
I seem to recall Doom sometimes struggling to run smoothly in certain levels on my Cyrix 486DLC-40.
I know that, back then, a framerate below 30fps was acceptable but, I always tend to notice this and it frustrated me.
I would still recommend at least a 486 DX2-66 with 8 MB RAM for a more pleasurable playing experience.
4 MB, in some cases, would require a user to create a boot disk to free up enough RAM.
Reply 18 of 20, by ik777
For gaming purpopse, 24MB.
later DOS game like Descent 2, Blood need pure 18MB without HDD swapping & smartdrive. (still need good graphic card for DX2-66)
Remember higher ram cause problems getting more UMBs with XMS & EMS service. (4MB is recommended only for Japanese Bi-sho-Jo games, higher is better if apps not need specific Memory service.)
Above 32MB can cause some apps insufficient memory because of wrong ram detection. In this case make a ram drive, reduce ram less than 32MB.
Reply 19 of 20, by Matth79
The "classic" tended to have 8x 30 pin simm slots loaded with 1MB for a total of 8, or later era maybe 4x 72 pin simm slots loaded with cheapskate 1MB for 4, with the option of loading with 4x 4MB for 16.
In Windows 3.1, I saw plenty of 386/sx systems starting with just 2MB (the minimum for Windows to go to 386 mode).
486's usually had 4 or 8, going to 16 if you needed to run something big.
