First post, by jolurove
Hello.
I recently bought an AMD K6-III+ 450MHz from ebay, and it's core voltage is 1.7V, my socket 7 motherboard's lowest voltage is 2.2V. Can I use this motherboard with this processor? I wouln't like to fry them, since it wasn't that easy to find any of them.
I searched an answer online but I couldn't find it.
Thanks!
Reply 1 of 4, by Skyscraper
2.2V is OK but you need good cooling and dont go higher than 2.2V.
At that voltage the CPU will likely run fine at 6x100 MHz, 5.5x100MHz is guaranteed.
Normally a motherboard that can do 2.2V also can do 2.0V, but the setting isnt always documented. Often you have 4 jumpers, the first jumper adds 0.1V the second 0.2V the third 0.4V and the forth 0.8V, no jumpers at all gets you the minimum voltage of 2.0V. Check if this is how your voltage selection block works.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 2 of 4, by jolurove
Thanks! That was quick! I have one of those startech coolers.. I guess it should do. And I didn't quite get that last part. Do I have to measure the voltage directly from the motherboard with a tester? I'm a little slow, sorry. But anyway, if 2.2V is OK then I should just leave it there don't I?
Reply 3 of 4, by Skyscraper
If you have 4 jumpers controlling the voltage and the 2.2V setting is set with Open-Closed-Open-Open then your V-core jumper block probably works as I described.
Using the documented 2.2V setting is the safer route.
