First post, by brostenen
I am trying to get an SCSI burner running as an CD-Rom reader under MS-DOS-6.22, using the Adaptec 1542-C controller and 50-pin cable.
I just need guidance on how to install the Driver for accesing the CD-Drive under Dos. Everything is set up correctly...
I can lowlevel format HDD's and I can partiotioning them and do a normal "format c: /u/s" and everything just boot's into basic Dos.
I don't think that the controller supports any boot from optical drives, so I must only be missing the MS-Dos-6.22 drivers for this setup.
Controller = ID:7
HDD = ID:0
CD-Burner = ID:1
ZIP-Drive = ID2 + Terminator
Controller is running IRQ-11, DMA-6(7) and I/O-340.
Reply 1 of 6, by akula65
Adaptec retail cards should include drivers on floppy disks. If you have lost yours, the PMC-Sierra site still has good support for Adaptec products:
AHA-1542C Page:
http://www.adaptec.com/en-us/support/_eol/scs … _isa/aha-1542c/
Accessing your SCSI CDROM under DOS
http://www.adaptec.com/en-us/support/_eol/scs … raccess_doc.htm
Reply 2 of 6, by brostenen
akula65 wrote:
Adaptec retail cards should include drivers on floppy disks. If you have lost yours, the PMC-Sierra site still has good support […]
AHA-1542C Page:
Thanks. Will have a good look at it, as this is new territory to me.
Used to deal with PATA and SATA only.
Reply 3 of 6, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Yeah, you need to install the card driver, the cards cdrom driver (both in config.sys) and mscdex driver in autoexec.bat
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 6, by brostenen
Tried loading the aspi driver in config.sys and it freezes. Any thought's?
Reply 5 of 6, by akula65
You said "ASPI driver" (as in singular). Did you load both the necessary drivers?:
http://ask.adaptec.com/app/answers/detail/a_i … ed-under-dos%3F
Reply 6 of 6, by brostenen
Yes... All loaded now. I sorted the issue out.
The reason was, that the ISA mem block base or something called that, was not enabled in the BIOS.
I used the EZ SCSI installation kit, wich has all the drivers needed for my setup. 😀
