Help on finding heasink glue, please!
First post, by brostenen
Have been looking at "adhesive glue" on Ebay. Most of what I find is just thermal grease and not glue.
Can anyone guide me to some of the real stuff, on ebay? Been looking for the cheapest avaliable.
Reply 2 of 17, by brostenen
A little over what I can find zallman glue for on the local shops.
Just thought that china would produce some more nasty stuff, that are extremely durable.
Reply 5 of 17, by brostenen
These looks like the same stuff, though I searched for both types...
http://www.ebay.com/itm/FD604-Heatsink-Therma … RIAAOxyaURThZk1
http://www.ebay.com/itm/1x-CPU-GPU-Thermal-Si … HEAAOSwk5FUweJ-
They are cheap... Just wonder if they are really nasty. Nasty as in "extreme binding and for love of all don't get on you'r hand's"
I want to use it for adding some chipset heatsinks (from dead mobo's) to some ram chips on various graphic cards and stuff like that.
Reply 6 of 17, by ODwilly
That is exactly what I used it for and it worked well, not as good as the more expensive stuff but better than I expected. It smells TERRIBLE. I think it takes awhile to cure so you have plenty of time to get it off your hands before it turns into a problem.
Main pc: Asus ROG laptop. I7-6700HQ, GTX 960M 4gb, 16gb DDR4.
Reply 7 of 17, by brostenen
ODwilly wrote:
It smells TERRIBLE.
That's the stuff I wan't. Can't argue on the price eighter. And the plus-side, I get to "fuck" mother nature on that cheap shipping from China.
How much will my shipment pollute I just ask 🤣 🤣 🤣 If you need to do it, do it right.... 😉
Naaa... For real, how is this even possible to do? Manufacturing and shipping at these prices?
Reply 8 of 17, by brostenen
Bought this one:
http://www.ebay.com/itm/FD604-Heatsink-Therma … GIAAOSws65Tmbmd
And 20 small 8x8mm alu-heatsinks if I should run low on the Chipset heatsinks that I have gathered.
Reply 9 of 17, by joe6pack
stuvize wrote:
You want something like "Arctic Alumina" never used myself but people say good things about it
FWIW, this is good stuff. I ordered some to stick a heatsink on the xbox 360 southbridge, and I've ended up using it for a ton of other stuff. Never knew I needed it until I got some 😀
Reply 11 of 17, by ODwilly
I love the Arctic stuff but hate the cost and semi-permanence. The trick with the Stars stuff is to do a thick glob instead of an even spread from what I understand, with a thin layer it lacks a good bond and falls off.
Reply 12 of 17, by TELVM
brostenen wrote:
... I want to use it for adding some chipset heatsinks (from dead mobo's) to some ram chips on various graphic cards and stuff like that.
I just super-glue that kind of smallish heatsink stuff.
Super-glue (0.11 W/mK) isn't as good a thermal conductor as true grease, but is an order of magnitude better than nothing (air = 0.030 W/mK), and in practice works fairly well.
Let the air flow!
Reply 14 of 17, by alexanrs
dr_st wrote:
I may have been out of the loop too long, but why would anyone want thermal glue as opposed to regular thermal grease?
To attach heatsinks to GPUs/chipsets or anything that does not provide a way to attach one, like holes.
