Reply 20 of 28, by saturn
kanecvr wrote:
Fun little fact - while playing around with the drivers, I found "digital SLi" and "SLi Compatibility" under 3dfx advanced features tab. Makes me wonder if one could chain up two voodoo 4 4500 or voodoo 5 5500 PCI w/o a bridge for better performance...
Wile technicality possible it will not have the affect you looking for. We were taking bout it over on falconfly.de always back.
Also a 1.5v agp slot will not do anything bad to the card other then make it unstable. If I recall most off brand 4500 had problems with 4x and 1.5v
Reply 21 of 28, by PCBONEZ
According to this thread here: http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=2104
Some of those cards were keyed incorrectly such that despite the 4x keying they were only 2x cards.
I suspect that some companies upgraded their PCB layouts to 4x before they exhausted their stock of 2x chips.
Reply 23 of 28, by PCBONEZ
anthony wrote:
There are no vsa100 chips with support only 3.3v and/or 2x mode. All of them are support 1.5v/4x mode and 3.3v/2x mode at the same time.
Good to know.
anthony wrote:
Configuration done thru strapping pins
I'm not familiar with the expression "strapping pins".
This particular card has only worked with AGP 2x set in the BIOS.
It sounds like a PCB revision problem to me. - As others have suggested.
Reply 24 of 28, by kanecvr
Might be worth a try - my soldering skills are more then enough for the job, I have a hot air SMD rework station and the paste required to solder said resistor on - what I need to find is a tiny 4.7k smd resistor, and that shouldn't be very hard.
On the 3DFX agp 4x version R97 is indeed bridged by a resistor: http://hw-museum.cz/data/vga/pic/big/3dfx_Voo … rev._3900_F.jpg Pic isn't large enough to read the value, but it could be a 4.7k.
Reply 25 of 28, by havli
I don't think R97 on reference 3dfx V4 is the same one as on PowerColor. Its position on the PCB is different and I believe it is not AGP related.
Anyway, I took some photos of that area, maybe it will help you.
Reply 28 of 28, by kanecvr
I did. We were discussing how to mod the card to accept 1.5v signaling.
After sorting out my KT333 GA-7VRXP rig I stuck the voodoo 4 in and did some bencheies :
16bit 640x480 - score is DOUBLE what my Voodoo 2 SLi setup scores with an Athlon64 3800+ in the same conditions 😜
16bit 1024x768 - score is... quite a bit higher then my Voodoo 3 3500TV..
32bit 1024x768 - about as fast as a geforce 2 MX
Played a little Quake 3 arena too - set res to 1280x1024, 16 bit color, bilinear filtering, lighting: Lightmap, Texture quality: default and Geometric Detail: high - it gets 38.6 FPS in demo001
