First post, by brostenen
I have been reading in the manual, that whenever I use one PCI card, I should set the IRQ to pull up, and when I am not using an PCI card it should be set to Pull down. Then I thought about what this is, and in the last 3 or so day's, I have not really found an answer to this.
So... What is this exactly? And why does it require such specific settings? In short... What is it about?
Reply 1 of 6, by HighTreason
It is an electronics term... So far as I know, such as in; https://en.wikipedia.org/wiki/Pull-up_resistor
I would have explained it, but I think the article is probably better... Well... OK, I'm being lazy.
I guess they must be using pull-up/down resistors somewhere on the board. Or else, are implementing something to ensure a certain logic level is reached on the interrupt pins. Either way, the jumper settings are a bit tedious on this board.
Reply 2 of 6, by gdjacobs
First, what is an IRQ? In a nutshell, a device on your computer called the interrupt controller listens to the appropriate pin on the card for the voltage level on that pin to be disturbed from normal. If it picks up a signal, it alerts the CPU. On PCI devices, the interrupt pin will naturally be at high voltage and be pulled low by a transistor on the card to signal an interrupt. A resistor safely connects the pin to positive signal voltage to pull the pin up to a high signal when not active. This is also preventing shorts.
ISA devices are naturally opposite, so you need a pull down resistor.
Reply 3 of 6, by kanecvr
From what I understand, you should pull down the IRQ used by a PCI device - say you're using a PCI video card on IRQ 10 - then IRQ 10 should be jumpered to pull down. Not 100% sure but will experiment myself.
Reply 4 of 6, by gdjacobs
PCI is active low, so the resistor will be pulling high, and the mosfet will pull low when the irq is triggered.
Reply 5 of 6, by brostenen
Thanks all... So..... I just follow the manual and do what it say's then. 🤣
