First post, by xjas
So I keep reading in places that the AWE64 was available in a "standard" 1MB configuration along with the value (512kB) and gold (4MB). I don't think this is true. I've personally *never* seen a 1MB AWE64 either in person or online, nor have I been able to dig up a CT-number for one that isn't cross referenced elsewhere to a 512k card.
Anyone have any insight into this? Did they plan to release one & then dropped it when they realized they were just splitting their own market or what?
Reply 1 of 6, by Skyscraper
They are all 1MB! 😉
It just that its ROM and not RAM, when it comes to RAM you are 100% correct, 0KB, 512KB and 4MB are the only existing sizes with the 0KB versions beeing labeled as SB32 although they are AWE64 based.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 2 of 6, by jesolo
Refer this topic: Re: "Standard" 1 MB RAM AWE64
It basically addressed the same question you raised. However, there never was an AWE64 that had 1 MB of RAM on board (the standard General MIDI sample set was stored in a 1 MB ROM, which I think is where the confusion might have come in).
You either had a "value" card with the standard 512 KB RAM on board or the AWE64 Gold that came with 4 MB RAM on board (apart from some other "extra" features).
However, if you had the RAM expansion modules (there were some cheaper after market options available), you could basically upgrade your RAM to 28 MB.
Refer this topic for some info on the Simmcon adaptor: Simmconn AWE64 Adapter.
Quite an interesting story on the 2nd page of the guy who manufactured this particular adaptor.
PS: The SB32 was actually a derivative of the AWE32 and not the AWE64, since some SB32 models still had the simm expansion slots but, no Waveblaster connector or the CSP (ASP) chip. It also utilised the Vibra chipset that didn't have any treble or bass options in the mixer but, some users have reported "cleaner" sound output on these models.
Reply 3 of 6, by RacoonRider
0KB version is SB32 CT3670. And it's probably the only AWE64-based card to have SIMM slots for expansion, which, in my eyes, makes it superior to AWE64. I mean, you sacrifice WT header, but it's buggy anyway.
Btw, CT3670 is very common in Russia, I got three of them, but for some reason I never made pictures.
jesolo wrote:
PS: The SB32 was actually a derivative of the AWE32 and not the AWE64, since some SB32 models still had the simm expansion slots but, no Waveblaster connector or the DSP chip. It also utilised the Vibra chipset that didn't have any treble or bass options in the mixer but, some users have reported "cleaner" sound output on these models.
Well, this is just nonsense. There were different models of SB32, based on AWE32, AWE64 and Vibra16.
Reply 4 of 6, by Skyscraper
RacoonRider wrote:
0KB version is SB32 CT3670. And it's probably the only AWE64-based card to have SIMM slots for expansion, which, in my eyes, mak […]
I also think I have at least two CT3670, they are nice cards indeed. I thought an AWE64 based SB32 version without the SIMM slots existed but I probably got it confused with some AWE32 or Vibra based version or perhaps some strange cut down OEM card.
Reply 5 of 6, by jesolo
I never considered the SB32 models to be value orientated versions of the AWE64. They were originally introduced in June 1995, whereas the AWE64 was only released in November 1996.
However, looking at some of the model numbers, that might be true. Were there ever SB32 models with a DSP chip that had version 4.16?
That should confirm whether any of these were manufactured/released around the same time as the AWE64.
PS: According to Creative's own website, the CT3670 is an AWE32 and not a SB32.
Reply 6 of 6, by RacoonRider
It's an SB 32 PnP 😀
http://s1260.photobucket.com/user/RacoonRider … ppynmb.jpg.html
Here is a more or less complete list of SB32 cards:
CT3930 - Vibra16 chip - CT2501
CT3600 - CT2502
CT3620 - AWE32 chips - CT1741/CT1745
CT3670 - AWE64 chips - CT8903/CT1745T
