First post, by emosun
so it's a packard bell m415. I'm trying to install windows fundamentals (insert comment about how it should have 9x/ windows xp is blasphemy here)
The setup goes perfectly , but then it get to the "installing plug and play devices" portion and it never moves on from there. The mouse is always still responsive so no hard freezing. I removed any hardware that I thought it might have trouble with like the gpu and sound card. I tried toggling all the little options in the bios for turning onboard devices on and off.
Kinda at a loss at what to do next.
Other xp disks also hang in a similar fashion. I only got one xp install to work and the machine actually runs a copy of xp pro that has been stripped heavily to accommodate 96mb of ram. But I really want to try fundamentals on it as it's made to run on machines like this , just having trouble installing it.
Reply 1 of 15, by emosun
Could I install fundamentals using a different machine , then move the drive to the packard bell?
I get the feeling it'll need some form of repair installation in order to work with the packard bell board once it's moved , maybe this could be an option?
Reply 2 of 15, by alexanrs
Have you fiddled with the BIOS' plug'n'play options? Disabled as many onboard stuff as possible? Disabled some ACPI stuff to test? Sorry, I don't own such a machine to help you further.
Reply 3 of 15, by emosun
The bios is really basic. there isn't even a plug and play option.
There just the drive section , boot sequence , and section to disable onboard devices.
Is there a way to install the os using a different machine , then transfer the drive to the packard bell and fix the installation so the packard bell will boot it?
Reply 4 of 15, by alexanrs
You can just plug the HDD in another machine and try - but it will install drivers specific to that system. Try using something that resembles the hardware your Packard Bell uses (e.g. the chipset and graphics card) for higher chances of success.
Oh, and please do look for BIOS updates. Perhaps Packard Bell released something to address whatever triggers this bug.
Reply 7 of 15, by emosun
alexanrs wrote:
If Windows 2000 also triggers this... there might be. Though I would not bet on it.
Windows 2000 does , however I think packard bell usa was gone by then.
If there is a guide on how to transfer a windows xp drive without having to reinstall it , I'll try to find it and see if that helps.
Reply 8 of 15, by JayCeeBee64
Rank Retired
Retired
Try these links:
https://www.raymond.cc/blog/move-windows-xp-h … creen-of-death/
https://www.gcsdstaff.org/roodhouse/?p=867
Either one should work, provided the Packard Bell doesn't have any more "hidden" surprises.
Ooohh, the pain......
Reply 11 of 15, by Snayperskaya
When I worked on field support I had a Windows XP Image (Norton Ghost) made in a socket 462 nForce-equipped board. Since XP wasn't aware of any of those HWIDs (thus no prebuilt driver for that chipset), it just used its default, generic ones. It was the perfect image for deploying at almost every scenario - the only problem was that you had to set the SATA disk controller to IDE/legacy mode on modern motherboards ("modern" = having SATA 😁 ).
I've read about JayCee's tip before but found out that my method was a bit more efficient (this and drp.su's driverpacks were great time savers).
emosun wrote:
the machine is also stopping when trying to load hirens boot cd. Again , not hard freezing , just stopping.
Maybe the cd drive isn't fast enough?
Try FalconFour's Ultimate Boot CD. It's a optimized Hiren's Boot CD with more tools under DOS and MiniXP.
Reply 12 of 15, by JayCeeBee64
Rank Retired
Retired
emosun wrote:
the second link doesn't work
You're right, the server doesn't respond. It was working last night; hopefully it will come back online soon.
That is a cleaner and more practical way to transfer XP from one PC to another. I imagine Intel 875P boards will do as well.
Just one question, what about the activation process? (unless you were using XP Pro Corporate ^^ ).
Reply 13 of 15, by emosun
also doesn't boot I get a "windows failed to open the ramdisk image" when trying mini xp
I also tried mini linux and get a cmov error for that.
This must be the most incompatible computer ever. 🤣
Reply 14 of 15, by JayCeeBee64
Rank Retired
Retired
Most current versions of Linux don't have support for Pentium CPUs, only Pentium Pro and above:
http://askubuntu.com/questions/115690/this-ke … u-error-message
http://www.pclinuxos.com/forum/index.php?topic=107279.0
As for the MiniXP error, could be bad system memory or a faulty CD drive.
Reply 15 of 15, by Snayperskaya
JayCeeBee64 wrote:
You're right, the server doesn't respond. It was working last night; hopefully it will come back online soon. […]
Yea, the image was made from a XP Pro Corporate (we used a Open Licence or something).
You can always try the sysprep method, although I'm not sure FLP supports it:
http://www.answersthatwork.com/Download_Area/ … XP_PC_setup.pdf
