Reply 40 of 42, by PCBONEZ
wrote:Today I am going to test your solution. Can it be a long term solution or is something to find out the problem?
*If* it works........ It will most likely be a temporary fix.
I say that because good caps would not get this bad in only a year.
However it should repeatable and it -might- buy a couple of years more use before you have to recap.
