First post, by dirkmirk
I was going through my collection today and made an interesting observation, one of my socket 370 Boards is an AT form factor!
The model is a Gigabyte GA-6VA7+ which supports up to an 8X multiplier and up to 150mhz fsb which got me thinking, I should make another oddball build this time a board like this in an AT case, ie a wolf in sheeps clothing.
What CPU would give the best chances of overclocking and performance? The site says it supports up to a 1ghz coppermine/133 or a celeron 1.1ghz/100, the boards supports 140/150mhz overclocking, VIA Apollo Pro chipest.
edit: I think I read that the multiplier goes up to 8x for future cpus..... Is that relevant or because the multiplier is locked is disregards the motherboard settings?
Are their any newer boards that come in an AT form factor? I guess by that I mean the old style keyboard connector and AT power supply.
http://www.gigabyte.com/products/product-page … spx?pid=1442#sp
Reply 1 of 13, by PCBONEZ
I went on a search quest years ago to find AT boards that supported 1GHz or better CPUs.
There were a few. Not many. 1GHz was about the max.
And no. I don't remember what they were. Too long ago.
Reply 3 of 13, by Skyscraper
I think you should be able to find a AT board that will let you run a FCPGA modded P3 1400-S @ 10.5*150 = 1575 MHz.
You need a motherboard with a VRM that can support the voltage, a PCI/4 divider and a AGP/2 divider, VIA Apollo Pro boards should support all that.
A good FCPGA slotket with VID selection will make it easier to find a suitable motherboard as the motherboard dosnt have to support the exact voltage the CPU wants, just close enough...
Another choice is a Tualeron, I run a FCPGA modded Celeron 1400 @ 14*112 = 1570 Mhz on an early revision Abit BH6 (Slot-1, 440BX, ATX).
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 4 of 13, by PCBONEZ
Don't forget about Slot A and Socket A.
While these are probably not very desirable boards for gaming it does show that some AT boards with Socket A existed.
http://www.motherboards.org/mobot/motherboard … 0Chips/M812LMR/
http://www.motherboard.cz/mb/jetway/849BS.htm
Reply 5 of 13, by kanecvr
^ beat me to it. I have a weird Lucky Star slot A AT form factor board witch I can only run with an ATX PSU since AT PSUs aren't really built to handle power-hungry systems. I also have a Matsonic ALi chipset socket A AT form factor board, but it will only fit in some AT cases (it's huge) + it's plagued by the same issues as the Lucky Tech. I actually killed a 250W AT PSU while testing it.
Not to mention the Matsonic comes with two PS/2 ports one where the AT connector should be, and the other right underneath that one, so you need an AT case that has both DIN and mini-din cutouts. The Lucky Tech comes with one DIN and one Mini-DIN right next to it.
Reply 7 of 13, by PCBONEZ
dirkmirk wrote:
Thanks guys I'll keep an eye out, hmmmm thats another challenge getting a socket board A running with a 250W power supply!
Most of those have power connectors for both AT and ATX PSUs.
Reply 10 of 13, by PCBONEZ
dirkmirk wrote:
Would the AT power button power on through the ATX power supply?
To convert the switch to ATX you just change it to a normally open momentary contact type.
Alternately most reset switches can be re-purposed to power-on an ATX PSU.
On ATX the switch connects to jumpers on the mobo, not to the PSU.
Reply 11 of 13, by gdjacobs
I see what you were getting at.
What PCBONEZ said, plus ATX to AT adapters often use the latching switch to close PS_ON to ground.
* For bonus marks, show how you could build a rising and falling edge detector circuit to use the standard AT switch to feed into the south bridge PS_ON latch.
Reply 12 of 13, by PCBONEZ
I'm too lazy.
If you just HAVE to use the old AT switch it can be done by getting rid of the line voltage wires and using one contact set in the switch.
But because the ATX needs a momentary contact you would have to push the switch twice fast.
On then OFF (closed then open) in so far as the switch position.
On ATX a power button that is left shut may turn the system right back off.
It's the same as holding the power button in to turn it off which is a feature of ATX.
Reply 13 of 13, by alexanrs
As long as you don't exceed the 4-sec most motherboards use to force a shutdown, you don't really have to rush it. Anyway, changing the switch is a FAR more elegant solution anyway... Or just ignore the switch altogether and set things up so you can turn it on through the keyboard.
