Reply 22 of 22, by Mamba
Changing the SATA cable did nothing, the crackling sound while HD is working persists.
I think it's because in the Fractal design CORE3300 the SSD is mounted behind the motherboard tray (as an option I adopted), maybe it's not properly shielded.
The QX6700 has been mounted, now I get this:
It's the best I can do for with 4 sticks of RAM, it appears that the 865PE chipset is limited to that quantity. Right?
