alexanrs wrote:PCBONEZ wrote:Believe it or not USB keyboards have chips in them.
You need to know what it is to find a compatible driver.
Unless the keyboard is a weird one, it should adhere to the HID standard and therefore be covered by the generic drivers present in Windows 98 and beyond. And since Windows has shipped with the generic HID drivers since then, many mice/keyboards do not ship with specific drivers. And the ones that do, unless they are old enough, will probably not bother with Windows 95 (non WDM) support.
The OP is trying to get USB working with W95 which makes what happened with W98 irrelevant.
Even then, 'generic' drivers (WDM or not) originally come from the manufacturers who submit them to MS for inclusion in the OS.
Even generic drivers are dependent in the chip(s).
The PCI\VEN_xxxx&DEV_xxxx for chips compatible with said driver is buried in the driver somewhere.
For W95 the manufacturer would be responsible for USB keyboard drivers because they were not standardized or accepted by MS yet.
- ALL USB keyboards were weird ones when it comes to W95.
You could do what I do and avoid the whole problem by using PS/2 ports for mouse/keyboard.
