First post, by computerman1k
Hi
I just got a new machine (brand new in box) seems like it was supposed to be used as a POS machine
It's by NCR it's tabled as "Class 3259" by the company
LPX motherboard from Intel "RU430HX"
Theres a bunch of these on ebay I came across mine from a different place (it was still in it's box and appears unused)
http://www.recycledgoods.com/media/catalog/pr … -3259-25.18.jpg
Anyway I couldn't wait to put a Voodoo 1 and AWE64 inside and get it going as a Win95 gaming machine but no expansion cards I've added to the machine except the Voodoo 1 will show up on Windows 95 Device Manager
I put in an ISA network card; a PCI network card; an AWE64; all the cards are working I tested them (except the PCI network adapter) in a different machine side by side
I installed DOS and ran the SMC utility it will not detect the ISA network adapter regardless of the slot I used on the riser card; the AWE64 is nowhere to be seen in Windows 95
The only card that will show up is strangely the Voodoo 1
All the other onboard hardware works perfectly; the system itself is fine the CD ROM I added works; i expanded the memory that works; the Floppy and Seagate Drive works; the PS2 ports work etc
I have no idea why no expansion cards bar the Voodoo 1 show up in device manager
I checked the BIOS and cycled through all the settings with respect to Plug N Play options
I dont understand why my other Socket 7 machine picks everything up and this one doesn't I just hope the riser card isn't damaged or it doesn't need a bios update because I cant find one for this machine (thats safe to install with instructions anyway)
Thanks let me know if anyone can help the motherboard is a RU430HX from Intel
Reply 1 of 17, by shamino
I don't know much about 3Dfx cards but if I'm not mistaken, the Voodoo1 doesn't use an IRQ channel. Not sure about DMA.
I wonder if the fact that it doesn't need those resources might be why it's getting detected, while the other cards aren't.
Perhaps there's some problem happening with allocating resources to the expansion cards. Does the BIOS need you to assign any of that stuff manually?
Reply 3 of 17, by nforce4max
Yuck that from factor, I am surprised that you are getting this issue but this is another reason to avoid these point of sale systems. ISA DMA might not be working or supported with this board :s
Reply 4 of 17, by computerman1k
Thanks for the replies what you're saying makes sense.
In the BIOS there are options for setting Plug and Play features for something like
Windows 95 and Other and Off/None
When none is selected you can reserve IRQ/resources for an ISA card
It comes with onboard VGA USB Serial Parallel IDE the usual stuff. I turned some off to free resources but even with them all on there were still resources that were free in the list when I switched off the PlugNPlay option
Surely no would release a computer that you couldn't expand yet include expansion slots
The bios version i have is 1.00.07DLO
I found an updated bios on the NCR website "1.00.09.DLO
http://www5.ncr.com/support/support_drivers_p … pc_library_3259
the problems are
a) theres no instructions on howto apply the bios; only a set of binary files and some "iflash.exe" utility so I'm not brave enough to proceed
b) it mentions it corrects an bug with an onboard VGA option that isn't featured on my version. I have the Trio64V+ the description of the BIOS (which has no readme file it's right there on the website next to the download link) mentions it corrects an issue with the Virge option
I dont know if applying the bios update (if I could figure it out despite no instructions) would brick my motherboard because of the different VGA controller, perhaps it also overwrites the BIOS for the VGA controller; maybe thats integrated into the systems BIOS
So I'm a loss here I've got no way to actual expand the machine
IRQs for the onboard devices must be assigned properly because I can use a mouse and I installed an optical drive
I haven't tested the onboard USB but I recall it now showing up at all in Windows 98 and showing up with an error in Windows 95 under some generic device name
I'll look it it further and post a list of the files from the NCR website with respect to the BIOS update
Reply 5 of 17, by computerman1k
Also the machine shipped with a Network Adapter in the ISA slot which I tested it wouldn't work either (the light was always on) I didn't test adapter with my other machine so I'm unsure if it's faulty
edit: heres a picture of the contents of the bios update the .exe extracts a bunch of files
http://postimg.org/image/5frv6nch5/
the contents of the autoexe.bat file are
it runs "beep.com" then runs "iflash.exe" with no arguments
Reply 6 of 17, by computerman1k
i did some more work on the machine
i updated the bios all went well it's version 1.00.09DLO now
but still nothing; not a single ISA/PCI card is given resources BUT
i found in the manual and on the motherboard some headers (i cant do anything now i locked the machine away just before i discovered this information)
called get this: "riser card configuration headers" it's 6 pins 2 stacks of 3 and 2 jumpers
you wont believe it but the manual says nothing more about these jumpers so i dont know where to set them
there are 9 possible combinations
i will try all of them tomorrow and hopefully it doesn't alter voltage and destroy any add-in cards
Reply 8 of 17, by computerman1k
tried all the jumper combinations- nothing worked
i think some circuitry is damaged with respect to setting the jumpers on the motherboard so the board cannot recognise the risercard and assign resources; this is why the voodoo will work but not any device that requires a resource
Reply 9 of 17, by shamino
Does that board have a socketed BIOS? If it were to get a bad flash, do you have a way to program a replacement chip outside the machine?
If you feel safe trying it, then I wonder if an Intel BIOS would be better for PC usage than the NCR BIOS.
Reply 10 of 17, by shamino
I tried to find an Intel manual for this board but couldn't find one.
I did however find documentation for a couple of other LPX form factor Intel boards. Both of them have the same 6pin jumper block for configuring the PCI riser. Both of them had the same jumpering scheme, so I'm guessing the RU430HX probably also uses the same scheme.
This link is the jumper configuration info for the Intel "Advanced/RH".
https://web.archive.org/web/20040404140846/ht … rh/rh_confg.htm
Maybe some of the info is relevant to the RU430HX, even though it's not the same board.
The thing I notice though is that the jumper options listed by Intel only address either having a riser with 2 PCI slots or 3 PCI slots. There's no option for 1 PCI slot, as what is shown in your picture. Did it come out of the box with those jumpers set in some other arrangement than what Intel shows?
Reply 12 of 17, by computerman1k
i have 2 pci and 2 isa slots on the risercard theres a pair on each side
i set the jumpers in all possible locations but theres only really 2 correct settings as listed on the article by "shamino"
i tired both extensively there was no change in behaviour
strangely if i cross-jumped the jumpers vertically there was no change either except if i cross 3 and 6 the pair on the left most end closest to the external ports on my board; theres no video out and no beeps the power light flashes and system appears to running underneath
perhaps the other 4 pins are not functioning and they dont crash the system when link them vertically which is obviously wrong
the risercard does work with my voodoo 1 geometry acceleration module in either pci port
i think NCR ruined the machine in some way they're a bunch of amateurs i should have never trusted a machine from the likes of them
i've locked it away in the shed. i will salvage the seagate magnetic disk drive when i need it for a new project
disappointed i wanted the LPX formfactor socket 7 because it's compact and excellent looking now i have to use my bulky overly large ATX socket 7 instead which is more than twice the volume but at least it works
Reply 13 of 17, by computerman1k
the board must have a bios but i dont know where it is it's not a large chip like the classic motherboards have
i haven't removed the risercard to inspect it but it does work with my voodoo 1 geometry acceleration module on either PCI slot
I will remove it at some point but i will take a break from this machine
Reply 14 of 17, by computerman1k
the got the PCI network card working turns out only the ISA cards wont work
I did more testing today; for some reason it wont assign resources to any ISA card
I tested 2 network cards and 2 sound cards zero functionality one was a AWE64 i know works in windows 95
i tried all the settings reserved IRQ set PnP for Windows 95 none and other
zero success
Reply 15 of 17, by shamino
Plug and play ISA cards always confused and frustrated me. I have one such sound card that I'm pretty sure is dead, but given my history with those type of cards, I have so much doubt about getting them set up correctly that I feel like I'm never really sure.
If you have any non-pnp ISA cards, where resources are assigned by setting jumpers, it could be worth a try just to simplify the situation.
Since it's an Intel motherboard, the BIOS might be on a small surface mounted chip with tiny pins (SOIC or whatever it is) instead of a socketed PLCC or DIP. That's something I don't like about Intel boards. Supposedly their boards have a procedure to recover from a bad flash, but It hasn't worked for me when I tried it.
Reply 16 of 17, by computerman1k
well i got 1 isa sound card working about 1 in 15 restarts
it looks like a race condition when the bios assigns resources
switching off onboard devices doesn't increase the chance of success
theres definitely something wrong with this motherboard/chipset or one of the onboard devices
i'll have to make it work with an external parallel network adapter that works with my application (if i can find one) and use a PCI soundcard that way i can ignore the ISA slots entirely
