Best Slot1 440BX Boards
Reply 20 of 23, by Skyscraper
Totempole wrote:
Skyscraper wrote:
I would think a Coppermine Celeron 1100 is about equal to a P3 866 on average with the Celeron 950 beeing equal to a P3 733. It was some time ago but I did quite alot of benching comparing Coppermine Celerons and Coppermine P3s. Some memory bottlenecked stuff will run close to 33% faster on the P3 (clock for clock) but stuff that fits into the Celerons 128KB L2 will run almost as fast on the Celeron as on the P3 (clock for clock).
But a Celeron 950Mhz is still faster than a Pentium 3 750Mhz on a 100FSB right?
Yes it should perform at least as good as a P3 800((100) and probably more like a P3 850 in most cases.
You can always download some benchmarks and run some tests to see how your hardware performs with the two CPUs.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 21 of 23, by Totempole
Can you suggest some good CPU and GPU benchmarking tools? Particularly ones that work well with 90's systems?
Thanks.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 22 of 23, by Skyscraper
In this thread benchmarking is discussed and there are links to the benchmarks.
VOGONS Benchmark archive?
You should focus on benchmarking games you like to play though.
Reply 23 of 23, by Tertz
If you are interested in games, then use games as benchmarks. Check wich ones were used in hardware reviews of that times to compare the performance.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
