First post, by buckeye
Found a rare 1ghz P3 slot 100mhz for sale and was wondering what mobo would be compatible. Currently all I have is a Intel SE-440BX which support maxes out to a P3 450 at 100mhz. Maybe a 440ZX?
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
MSI x570 Gaming Pro Carbon Ryzen 3700x 16GB DDR4 Zotac RTX 3070 8GB WD Black 1TB 650W
Reply 1 of 12, by Kahenraz
I have a VIA Apollo Pro board which is rated for 600/100 but has OC pins which worked up to 1Ghz. I'm currently using a slocket adapter though. Is it he 100Mhz bus variant that you're suggesting is rare? I think that's how I managed to get mine working.
This ASUS P2B-DS on ebay suggests that a 440BX could work with a 1Ghz chip with the right bios?
http://ebay.com/itm/201482415233
Reply 2 of 12, by brostenen
Don't know about boards such as Intel SE-440BX-2 and Asus P3B's though a board like the Intel-VC820 supports 1+ CPU's.
The problem with a board like the VC820 is that it has 820 chipset and no ISA slot.
A little searching came up with a possible candidate: ABIT BE6-II v2.0
Reply 3 of 12, by Skyscraper
Most 1999 models/revisions of BX boards and all from 2000 should work with a Coppermine 1000(100), the multiplier is locked so thats not an issue.
BX motherboards from 1998 often lacks VRM 8.4 (the VRM spec for Coppermine voltage range support), this can be worked around by using a Socket 370 CPU on a slotket with voltage selection as the VRM 8.3 spec supports 1.8V. With a Slot-1 CPU you need to use a tape mod which is a hassle so I would make sure to get a later BX board with VRM 8.4 support.
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 4 of 12, by brostenen
http://www.extremeoverclocking.com/reviews/mo … E6-II_v2_1.html
Sweet.... The BE6-II has onboard IDE-RAID controller. 😜
Reply 6 of 12, by shamino
I'm not really a fan of RAID for most desktop usage, but in this case it's nice to have because it's ATA66. I'd just use it in single drive mode.
It's a cool board. The BE6-II and BX133 (it's socket-370 equivalent, which seems to be pretty rare) have more tweaking options in the BIOS than I've seen on anything else. However, it's important to note that 440BX ABit boards have bad capacitors (I think universally so). They have to be replaced. Once that's done, they're awesome boards though.
It's sad to think how many of these boards ended up in the trash because of caps, but I think that's what killed most of them off a long time ago. Other than that issue they're probably my favorite 440BX motherboards.
I think all BE6-II boards will support coppermine voltage, but I'm not certain.
Generally speaking an awful lot of slot-1 boards have a VRM that supports Coppermine voltages, but your chances are best if you stick to later boards. The SE440BX is an early 440BX board so it's probably too old for it.
Reply 8 of 12, by RacoonRider
I'm leasurely building a rig around a slot 1 PIII-800 and ASUS P3V4X. P3V4X is surely a nice board, a little moody due to VIA chip set, but overall well-built. Will be a couple % slower than a BX tough.
Reply 11 of 12, by chinny22
As mentioned above any BX based motherboard can support a Coppermine as long as it has the updated VRM
I have a Dell branded SE440BX board that shipped with a P3 500 working happily with a P3 1Ghz. I also know Gateways used Intel SE440BX boards round the same time AND as a bonus had the standard ATX pinout, unlike its Dell brother
I also have a early Asus P2B-DS which cant, There is good guide here on which Asus BX boards support later CPU's
http://homepage.hispeed.ch/rscheidegger/p2b_p … pgrade_faq.html
