First post, by Orkay
- Member
Last night, I got a Socket 7 motherboard in the mail, specifically a MSI 5128. I'm awaiting a replacement RTC battery for it, but that's not quite the point here. The issue I have right now is the onboard PS/2 mouse port being blocked off by three fourths of the tower chassis.
The motherboard does have a header to connect an alternate PS/2 mouse port, and I do have one, but it's not working right now. It may have to do with the dead battery not holding CMOS settings, or I fried the external PS/2 connector from plugging it in the wrong direction. It could even have been fried long before when I tried getting the PS/2 mouse connector to work in a Shuttle HOT-433, version 4.0. Of course, later I learned the HOT-433 doesn't support a PS/2 mouse because it has no AMIKEY chip.
Now for the internal mouse port in question... was the motherboard expected to be installed in a specific AT case design? Is there a better way to mount the motherboard in my case? I know it barely has any holes for gold screws, greatly favoring these plastic mounting things (whatever they're called) instead. Even if I did mount the motherboard differently, that would consequently block part of the AT keyboard port. It seems I might have to modify the case in some way, as good and affordable AT cases are not consistently available.
